Different Diff Output Shafts
Can anyone enlighten me as to when the change from narrow, shiny shafts to thicker black output shafts was made?
Presumably the change happened because there had been problems with the narrower shafts
'64 S1 Elan (Owned since '73)
'69 Alfa Romeo 1750 Spider Veloce (Owned since '77)
'70 Morris Minor 1000 (Owned since '85)
AlfaLofa - Third Gear
Steve,
I believe the uprated output shafts were introduced in 1972. I cannot believe that there were many problems with the original design, as I remember doing some crazy things with my Elan in the early years of my ownership, yet when I rebuilt the diff, it had the skinny output shafts, that looked like new, no sign of any twisting of the splines.
And in all those diffs that I rebuilt, approx 20, only 1 diff had twisted shafts. I shall post a picture if I get the time.
Leslie
Leslie
- 512BB
Interesting. My Plus 2 shafts were slightly twisted. Replaced with new shafts that came with the RD Enterprises supplied CV conversion. Maybe the extra weight of the Plus 2?
Stu
1969 Plus 2 Federal LHD
I gave my S4 a hard life in its early years and in about 1973 fitted 3 new oil seals to the diff because the nose seal was leaking. When I removed the shafts they were both slightly (but very visibly) twisted. I thought it best to refit them on the opposite sides thinking they would then straighten themselves.
I cannot remember what thickness of shafts I have (I assume thin) but the twist is most visible as it shows as a kink in the splined part as the shaft spline is longer than its female counterpart.
For some reason I did not change sides, but just re-installed them, that was 30 years ago and they have now done the best part of 200k miles.
I hope I have not woken any sleeping demons (in my shafts) after mentioning them!
Ian
Ian
Elanman99 - Third Gear
