PCV Valve & Catch can
PostPost by: Tonyw » Sat Sep 15, 2012 3:52 am
I was wondering why we do not have a PCV valve fitted to our TC engines and read most of what was in the archives, I then thought that if a catch can with two fittings was used a PCV valve could pull the fumes through the catch can which hopefully would leave most of the oil behind and nout foul up the spark plug, I was thinking of using a tee where the vacuum take of is for the brake booster.
Having a slight vacuum in the engine I think would go some way to help reduce oil leaks.
How is my logic?? has anyone tried this? do you think it would help?
Tony W
Second childhood? no just an extension of my first.
Tonyw
cron
