half shaft conversion length
PostPost by: zeteclotus » Tue Jul 31, 2012 3:59 pm
Hi, I made some TT style conversion shafts for another +2 I had but can not find the drawing I made.
Does anyone have the min max length dimensions of either the CV type or TT hardyspicer type.
hopefully someone has either a pair off a car or maybe has a drawing?
I remember the PCD of the output shafts is 95.8mm.
I have decided I am not prepared to pay ?90 each and spend a day changing rotoflex couplings every 6-12 months.
Also I want to make my own shafts so i can leave the fail safe pegs on the car rather than cutting them off.
Thanks in advance.
Paul
zeteclotus
PostPost by: vernon.taylor » Tue Jul 31, 2012 5:23 pm
Salut Paul
I probably won't be the last to ask, but I am the first - would you consider making an extra pair to sell (to me) ?
Vernon
vernon.taylor
PostPost by: elj221c » Wed Aug 01, 2012 6:16 pm
A search will give you this and doubtless others.
elan-mods-f31/elanmac-conversion-t24920.html
Roy
'65 S2
elj221c
PostPost by: Higs » Wed Aug 01, 2012 8:08 pm
Paul
Are you planning to shorten some driveshafts (by friction welding? by welding / sleeving?) or getting some custom ones made. I would be interested in joining in on this - I could get mounting plates made in bulk etc..
Let me know if you are interested....
Higs
PostPost by: zeteclotus » Thu Aug 02, 2012 2:35 pm
I bought individual bits welded them together and had them balanced like you would for a custom prop shaft.
last time I used standard hardy spicer flange joints weld yolks and a sliding joint. +2 adapter plates I made out of 8mm plate, all worked well I just wish I had kept the drawings.
The engine output was at least 145BHP I did replace the diff output shafts with some later type ones.
Hi Richard yes I would consider making a small batch alone or with someone, only thing is for a one of i will probably go the hardy spicer joint route but for a bigger batch I think CV joints are better
zeteclotus
PostPost by: john.p.clegg » Thu Aug 02, 2012 3:18 pm
PostPost by: john.p.clegg » Thu Aug 02, 2012 3:24 pm
Whereas mine are...just the same but with both ends sliding and covered in protective rubber..
[attachment=0]right rear drive 2.JPG[/attachment]
John :wink:
right rear drive 2.JPG and
PostPost by: zeteclotus » Thu Aug 02, 2012 3:29 pm
yes the ebay ones are very similar to what i made last time.
zeteclotus
PostPost by: john.p.clegg » Thu Aug 02, 2012 3:35 pm
The ebay ones are what I started with,but felt two ends the same would be better,so ground out the weld,sourced some splined bar and fitted centralising springs in each end...have a couple of spare H/S joints mounted on ali adapter plates in the shed so should either end loose a U/J it's a twenty minute job to replace...
John :wink:
PostPost by: c42 » Thu Aug 02, 2012 8:36 pm
Hi All
Try talking to these guys,
http://www.davemacprops.com/dmphome.html
Ask for John he is very helpful, no connection etc etc.
c42
PostPost by: lotusS2guy » Sun Aug 05, 2012 9:22 pm
Hi John
What's the story with the crenelated rear brake disk shown in your photo?
Herb
Herb
26/4618
lotusS2guy
PostPost by: john.p.clegg » Mon Aug 06, 2012 5:42 am
Herb
ABS...
John :wink:
PostPost by: vernon.taylor » Mon Aug 06, 2012 7:08 am
Salut Paul and Richard
An up to renew and show my interest. You'd make some grateful guys (and gals).
Vernon
vernon.taylor
PostPost by: zeteclotus » Wed Sep 19, 2012 10:29 am
To answer my original question
393mm from hub 3 way mount to diff 3 way mount at maximum drop for a late car with failsafe shafts.
Finally finished making them and fitting them, got the new MOT yesterday.
As I recalled ok for a one off make but too much finishing work is needed on some of hardy spicer forgings to stop interference at maximum droop and all the bolts are custom thread lengths etc.
I manage to make the shafts so the failsafe pins are retained.
Has one else noticed losing the rotoflex coupling makes the car feel faster! especially noticeable from 0-30. I wonder what the power loss is of rotoflex couplings.
The car is quieter so I managed to make them more balanced than the original shafts.
on the down side the exhaust smell is back.....
zeteclotus
PostPost by: vernon.taylor » Wed Sep 19, 2012 6:37 pm
... so no production run, I guess ?
Vernon
vernon.taylor
Next
