Diff carrier repair
David,
I've the same problem. Am just about to have some prototype "top-hat" washers
made (ie fitting one on each side of the ear).
Pattern was taken from an unused original diff casing, courtesy of Susan Miller.
Should be able to try these soon.
Stuart.
Stuart.
- stuartgb100
David,
The trial set will be in mild steel since fettling will be required.
I've measured several alloy cases and all are different.
Once a set is made, I'll post some pictures/diagrams.
Stuart.
Stuart.
- stuartgb100
