diff is coming out!!
Hi All,
This will sound the daftest of questions having built the car but..... Anyone got any demon method of diff removal/change? Bear in mind I will have the A frames off anyway and the car has Spyder driveshafts, so only 1 ' doughnut' each side to clamp up.
Can one remove the propshaft with the diff out?
Only asking!!
Alex...
Only asking!!
Alex...
Alex Black.
Now Sprintless!!
Now Sprintless!!
Alex, there is lots in the archives about diff removal and its not that difficult although a certain amount of "force" has to be used, some people seem to struggle with it and if the car has been jacked up below the diff it can distort the chassis which makes it more difficult, as you have a Sprint you have the strengthening bracket which has to be removed first.
The diff comes out of the left side and it will be easier to remove the propshaft with the diff out but I think you will still have to disconnect the gearbox mounting to raise/lower the gearbox to get the prop out.
A couple of thicknesses of heavy gauge polythene under the diff will make it easier to manoeuvre and prevent damage to the paint on the chassis. Also if I remember correctly you need to rotate the diff (when viewed from above) before you can roll it sideways off the LHS of the chassis - can't remember which way to rotate it however !!!
regards,
regards,
S4 DHC
S4 DHC
- oldelanman
Old Elan Man
What is wrong with old oil and oodles of Waxoyl?
May not look pretty but my goodness the chassis lasts. Mine is dirty, oily, original 1966
David
PS Diff removal is tricky if you do not have access to a lift - with one - a piece of oily cake.
??????????prevent damage to the paint on the chassis.
David
David
- bast0n
Alex, what happened that required removing the diff?? If I remember your laundry list of jobs for this winter, I don't recall any of them needing a diff removal. I'm sure I'm missing something here (as usual)
Greg Z
'72 Sprint
Greg Z
'72 Sprint
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
Wasn't it to fit a 3.5x diff for the forthcoming Alpine excursion?
BTW to remove the diff (apart from removing the top brace) I also found I needed to remove a section of the fuel pipe that went through the chassis section immediately above the diff. I don't know if that is the standard route for the pipe.
Paddy
Paddy
1963 Elan S1
paddy - Coveted Fifth Gear
Exactly..Thanks Paddy!
The Alpine trip though has now become a trip to Le Mans via goodwood. The 3.54 diff and adjustable A frames are to improve the motorway performance..
Cheers all.
Alex B...
Cheers all.
Alex B...
Alex Black.
Now Sprintless!!
Now Sprintless!!
Alex - Any chance of a blow by blow account of how things go with the diff removal? I've got to take mine out over the winter for an overhaul and as its been over 20yrs since I last looked at it - and then with the body off - things are a bit hazy.
Stuart
Stuart
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
Ok Guys,
I will photo' and discribe the job as I go. Having only 2k mls under its belt since full resto' and of course rebuilding the diff' complete with new mounts etc, I am not anticipating any problems. Everything was well copperslipped! And all new fastners used. But, this was all done with the chassis on a nice height trolly I could move around my garage. The body was at option 1 at the same time. So with any luck?
The other massive advantage is my 4 post lift. To be honest, if I did not have this I would give the job to a garage I trust (Few n far between!) The thought of doing it without the lift brought back memories of fitting the exhaust! Gods struth! getting below the car was a nightmare. Anyway.. I consider myself very very fortunate to A..Have the space and height.. and B.. the resourses to allow me to own such a wonderfull device.
It is awsome. Most of my mates use it also. I have even had our bike club round with bikes various up on the lift for service. I enjoy just watching (down John!!) and offering advice and help if needed. And I keep the kettle on the boil.
Needless to say anyone needing to use it is welcome (and that does include you Dave!) But I am aware of the logistics. But It's here anyway for anyone.. No charge.. Free. You can even use my tools. The only condition is .. I will not leave my Elan on the driveway, so the job needs to be finished same day.
Fair enough?
I am stocking up the fridge with 'fuel' and about to get stuck in. Trusty camera to hand!
Keep you posted!
AB......
Fair enough?
Keep you posted!
AB......
Alex Black.
Now Sprintless!!
Now Sprintless!!
alexblack13 wrote:Ok Guys,
AB......
Alex, you're not considering a move to the sunny south by any chance are you? I can recommend the Oxford area - all that culture, only ever rains when you're on holiday somewhere else, streets paved with gold etc.
Stuart
Stuart Holding
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
Don't tempt me Stuart! The weather up here just now is awfull. All those toys in the cupboard (Down again John!!)
and I can't take them out to play. Oh how I wish the climate was drier up here!
AB....
AB....
Alex Black.
Now Sprintless!!
Now Sprintless!!
Good luck Alex - what a few extra millimeters of clearance would have made to this area in terms of language and damaged paint!
- richard sprint
Deleted.
Beware of the Illuminati
