Propshaft Removal
I understand the propshaft can be removed with the gearbox (4 speed) and engine in situ. Anyone done it recently?
I understand the propshaft has to go through the chassis hole with the gearbox resting at the bottom of the hole. It looks rather tight, and I have a modified chassis from the 80's with strengthening fillets on the shock towers.
I do not know if the chassis hole that the gearbox goes into is smaller than standard . Does anyone have measurements on this hole for the standard lotus +2 chassis?
Dave Chapman
Dave Chapman
- david.g.chapman
I've removed one on an Elan S4 in situ, it was easy. The trick is guiding the splines back in to the trans. There's an access hole under the carpet with a rubber plug on the side of the bodyshell, by the right side seat next to the trans,(on a LHD car). I'd guess a +2 would be the same. Good Luck.
- 1964 S1
