Miller CV Shafts
• Page 3 of 3 • 1, 2, 3
Thanks.
OK, so remove driveshaft and refit outer end first, and there is enough room to engage the inner studs on the diff shafts, with the suspension in the droop limited position?
Malcolm
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
Hi there
The easiest way I found to fit the drive shafts on my Plus 2 was to undo the 8 off cap screws the split the aluminium adaptors from the CV joints. Fit the inner and outer aluminium adaptors to the diff flange and hub flange first then reinstall the drive shafts. They should go in easy this way as its only necessary to compress the shafts about 1/8" just to get them into the recesses in the adaptor plates. Just take care to avoid getting dirt into the exposed CV joins when the shafts are apart
Andy
Andy
- andyelan
Ok success, RHS fitted. To be clear this is on an S3 rather than Plus 2. With outer end driveshaft studs engaged first, with droop limited dampers there is still (just) insufficient room to engage inner studs, so it is necessary to have the outer wishbone fixings removed to give sufficient lateral room to finally engage the inner driveshaft studs.
Answered my own question!
Thanks to all for advice.
Malcolm
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
Well 1 month and 500 miles on these new driveshafts, they certainly made a big difference in the drivetrain and my confidence
Now to get underneath again and check the torque on the CV adapter fittings.
Malcolm
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
