Play in rear axle??
A 3 leg puller will damage the Hub.
- alan.barker
Follow the link I posted to the picture for the full gory details pertaining to my "hub off" adventure. You'll see that I tried a 3 legged puller (not against the hub flange, but against a ground down spinner that Sue sent me) and the result was a knackered puller.
+1 to Alan's post - we seem to be agreeing with each other quite a bit!
JonB - Coveted Fifth Gear
I had a similar problem many years ago and it turned out to be that the inner race of the outer bearing had worn a groove into the stub axle. At that time I worked in a large engineering works (midlands gas turbine manufacturer) and once the axle was out I took it into work and they metal sprayed and ground it back to its correct size. From memory it was worn about half way round the axle with a max depth approaching 1mm. I replaced the axle and both bearings and I partially filled the bottom of the strut casting with oil (half a cup full?). It?s been there ever since doing thousands of miles as a daily driver once repaired. Bound to get some comments about this repair, but 40 years ago with young children and limited finances that?s what I could afford. To be honest I?ve rebuilt the rear suspension recently and had forgotten all about this until seeing this post.
- Bigbaldybloke
I had the same problem the bearing had worn a groove in the stub axle.
A friend got it metal sprayed the same as you
Perfect repair and no problems.
- alan.barker
Four of us at least. I had one go like that about 20yrs ago but not knowing a metal sprayer had to replace it. For some unknown reason it?s still lying in my junk parts bin today.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
