Hissing sound from diff
• Page 2 of 3 • 1, 2, 3
JonB wrote:SENC wrote:As I'm about to reinstall my diff after pinion seal replacement, I have some concerns I'll find a similar issue. To avoid getting there and having to disassemble the entire rear suspension again, would I have any risk in running the diff without wheel load to test for whining?
If you have doughnuts they will be highly stressed by running them with the suspension in full droop. Same for CV joints (even on a +2 you'll be working them hard). Also, the sound I got only occurred when the diff was under load. To recreate the load, you might try to apply the handbrake.
If you run it without the wheels connected you won't get any loading, so the results might not be indicative.
Thanks Jon. I was thinking of running it before connecting the cv drive shaft - though I did realize the lack of load might not give me a real test.
Henry
69 Elan S4
65 Seven S2
69 Elan S4
65 Seven S2
- SENC
You say it was hissing when running, my experience with diff mal adjustment is a whine that can be noticed when either accelerating or decelerating and goes off with light throttle between both. Usually starting around 40 to 50 mph
Does your hiss start immediately ie minimum speed or higher.
Did you rotate the diff during finally tightening to ensure that the bearing cones were aligned properly
Is there any end play on the pinion at present, not easy to discern that would show it is under tightened
I am no expert just my experiences with diffs in cars owned by me and friends
Good luck hope it works out
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
This post was edited by the moderator.
Pete.
http://www.petetaylor.org.uk
Pete.
Steve! What are you doing up this time in the morning - I'll tell mother!
Did you fit a new crush tube? They are not supposed to be reused. (It has already been crushed!) Get a new one, stick it in, torque it up, off you go.
- vincereynard
HI Vince
When I asked about this I was advised that I could reuse it if I ensured the pinion nut was returned to its previous position (by virtue of counting the turns and lining up pre-made marks). According to what was said, I'd have to have the crown wheel out to do it right, if using a new crush tube.
lotus-gearbox-f37/pinion-oil-seal-t41056.html (second post).
I must have got the torque wrong.
jonB
jonB
JonB - Coveted Fifth Gear
Did you actually torque it to a set lb./foot on the nut as the correct procedure is by turning torque of the pinion shaft without crown wheel as you tighten the flange nut.
I don't know why they have a torque setting in the manual as the Ford spec has no set torque for the flange nut
If you were to use this setting to replace a pinion seal it would compress the crush tube again upsetting the pinion shaft turning torque setting.
This is only my assumption of the actions of torqueing up on replacing a seal
Good luck in a resolution
+2s130 1971
+2s130 1971
Well, this is useful:
http://www.skf.com/binary/30-285048/TT08_024.pdf
Whirring noise - points to loose pinion bearing preload. Other readings suggest the handbrake might be dragging (I did adjust it prior to this test run) and so I will loosen that off slightly first as it is easy to get at. Pretty sure it's the diff though...
Hawksfield wrote:JonB
Well, since the nut has a nylon locking ring you would have to apply some torque just to wind it onto the thread.. but as discussed, I followed Rohan's advice and reset the nut to the same place it was before disassembly. That said, I might be a turn out. I need to experiment with it to find out for sure.
JonB wrote:Well, this is useful:
Thx for posting, that will be useful.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
