Rotoflex bolts from Namrick
PostPost by: alan.barker » Tue Jun 27, 2017 3:15 am
img_0022.jpg and
Looks like it was a good moment to change :) .
Before fitting the rotoflex i remove the band and put 3 jubilee clips(joined) around outside to compress and aligne the bolt holes. I use an old brake disc to check position of holes and adjust clips.
PostPost by: StressCraxx » Tue Jun 27, 2017 3:39 am
loueelotus wrote:Hi.
Just wanted you all to know that Fastenal Company told me that they will make the bolts you want in the sizes you want. I just wonder about the quality of there product now..
Lou
Fastenal's products are good. We use them in our facility on pressure vessels. The custom products are domestic. It is up to you to specify what grade you want.
StressCraxx
PostPost by: alan.barker » Tue Jun 27, 2017 8:50 am
pereirac wrote:Just changed my rotoflex couplings and bolts.. The bolts were in a worse condition than the couplings!! :o
What position was the bolt fitted :?: I would check to see if the holes in the diff output shaft are still round if that's where it was. On a +2S i had a bolt that had worn a hole oval in a diff output shaft, i had to buy another output shaft :( . When i used to drive the car there was a clicking sound :shock:
PostPost by: pereirac » Tue Jun 27, 2017 2:16 pm
I wimped out and paid a friendly Lotus garage (GST Performance in Newmarket) to change the donuts for me as I didn't fancy a day on my back lying under the car in the garage. It's so much quicker when you can lift the car up. I still do need to replace one output shaft but that was on the other side, the hole was not too bad but the whole lobe which rubs against the donut was worn...
Carl
Carl
72 Elan Sprint
87 Excel SE
97 Alpina B10
http://www.lotuselan.co.uk
pereirac
PostPost by: types26/36 » Tue Jun 27, 2017 2:47 pm
pereirac wrote:The bolts were in a worse condition than the couplings!! :o
That looks like an incorrect bolt, judging by the picture the threaded portion of the bolt has too many threads and the shank (unthreaded part) too short.
types26/36
PostPost by: pereirac » Tue Jun 27, 2017 6:05 pm
The marks near the head are not threads just marks in the shaft, probably form the bolt rotating..
Carl
72 Elan Sprint
87 Excel SE
97 Alpina B10
pereirac
Previous
