Prop Shaft Bolt Spec
I just use 5\16" cap screws ( they have a small shank on them but it doesn't reach both flanges). I do them up pretty tight - can't measure the torque easily. I use fresh nyloc nuts every time they come apart, as much as anything because you have to tighten them with an open ended spanner/wrench and I want the hex to be in perfect shape.
I've never had bolts come loose, ovalised holes or cracked threads/flanges. I race pretty hard with 180 ish horsepower with and without limited slip diffs.
I'm with Rohan - I think there is a great deal of clamping induced friction.
Now, keeping wheels tightly attached and stopping standard (FIA) type clutch pates intact is a much harder problem!
Paul
Paul
Turning money into noise!
- toomspj
