To Rotoflex or not to Rotoflex
PostPost by: Matt Elan » Mon Jan 28, 2013 5:20 pm
After reviewing all the posts and otehr threads (and other boards etc) I came to the conclusion that double CV's were the way to go for fit and forget. Mick Miller Lotus are having a new batch of CV joints for Plus 2s made and should be in stock soon; I've got my name down for a set....
Visit me on matthewvale.com
Matt Elan
PostPost by: holywood3645 » Mon Jan 28, 2013 9:01 pm
Gearbox, Do you have any pictures of the finished items you made from the VW items?
Can you provide any pictures of the modifications you made to the shafts to fit the 2 seater elan application.
James
PostPost by: gearbox » Mon Mar 04, 2013 4:19 pm
holywood3645 wrote:Gearbox, Do you have any pictures of the finished items you made from the VW items?
James
Hi James, The process is fairly simple, find yourself a set of used OEM VW Bug shafts from a late 60's early 70's vintage. The difference is that the OEM shafts had circlips holding the CV's on to the shafts. The Bug never really needed these so all the new versions do not have this feature.
$(KGrHqVHJEgFBuod,vQIBQiR1WOc6w~~60_57.jpg and
I found a pair on ebay for $60.00 that were pretty dirty and greasy, but the shafts were in great condition.
IMG_7246.JPG and
The worst part of doing this job was disassembling the shafts, amazing how much grime and dirt accumulates over decades, plus the CV grease didn't help either.
030.JPG and
The next step was to cut the shafts to size. I am using a pair of diff output shafts with CV cups and on the outboard side I have 1/2 inch thick aluminum adaptors, so I needed to have the shafts to be exactly 12" in length end to end. The shafts are hardened steel, so the surface of the shafts are incrediably hard. I used a die grinder to cut the shaft in half, and then trimed them to size, 6 inches, on the lathe. I also wanted to make a sleeve to ensure that the both halves would be concentric when welded together. Since the shafts are metric and all I had were SAE drill bits, I decided to mill down the shafts to 15/16", or 0.9375", by two inches on both shafts to accept the 4" sleeve.
IMG_7257.JPG and
I went a bit overboard with the sleeves, but I wanted to make sure it will hold. I used a 4" long 1.375" diameter steel rod. Drilled a 15/16" hole for a friction fit for the shafts, drilled and countsunk 6 holes for plug or rose welds. I also milled down a relief for the CV boots to lock into on both sides.
IMG_7275.JPG and
I Tig welded both ends of the sleeve to the shafts and weled up the 6 plug holes to the shaft. Pretty much bullet proof at this point, but I am told that you can also use 1/8" tubing with a 1" I.D., or butt weld the shafts together. I've seen a Formula B car with butt weled shafts and after years it has not yet broken. But I didn't trust my welding skills so went with some extra insurance.
IMG_7293.JPG and
The finished shafts. A bit of paint and they look brand new.
IMG_7315.JPG and
I opted for a new set of GNK Lobro CV joints and they came with new boots and bolts. Apparently there are alot of cheaper aftermarket CV kits out there, but for $262.00 for 4 complete sets of OEM CV's, why not.
$(KGrHqJHJDYFC0sF1dRzBQy9Q90-Ig~~60_4.jpg and
Top picture is the Diff output shaft I bought on ebay and the guy also had the outboard adaptors. However, you can just make two adaptor plates for both sides for 1/2" thick aluminum, but these wrere nicely made, and for $388 shipped, it wasn't a bad deal.
I have this entire step by step project on my site at http://thelolaregistry.com/Projects/LOT ... ersion.htm so you can check it out. Let me know if you need any help, Allan
gearbox
PostPost by: Jaybee » Wed Aug 07, 2013 6:34 pm
Sue Miller cv conversion no drop limiters etc fit and forget . To many people on here that comment about things that they haven't done themselves and just make things up. Seats spring to mind I've just replaced mine in the forums every body's talking about what might fit but no one seems to have actually changed them! .john..........
Jaybee
First Gear
First Gear
PostPost by: AHM » Wed Aug 07, 2013 9:07 pm
Jaybee wrote:To many people on here that comment about things that they haven't done themselves and just make things up.
If you read this thread you will see that your comments are out of place.
If you read some recent history you will see that they are rather awkward.
Most people on here are knowledgeable and helpful.
AHM
PostPost by: vernon.taylor » Thu Aug 08, 2013 6:25 am
Salut
I'm afraid I have to agree, too. This forum is very frindly, helpful, informative, knowledgable and probably constitutes the most complete resource for Lotus Elan and Plus 2 cars on this planet.
Please share, don't flame ;-)
Vernon
vernon.taylor
PostPost by: Jaybee » Sat Aug 10, 2013 3:29 pm
You are correct in some of your comments but sorry I stand by my findings and only comment on the things I have done ,by that I mean facts not guess work and assumption . Sorry it would appear I'm a boat rocker and not a lamb agreeing with others for the sake of it.
Jaybee
First Gear
First Gear
PostPost by: AHM » Sun Aug 11, 2013 1:06 am
Rock the boat? Hardly!
Do you want to tell us something about driveshafts?
AHM
PostPost by: Mazzini » Sun Aug 11, 2013 7:33 am
AHM wrote:Rock the boat? Hardly!
Plus one to that.
I'm running US CV's driveshafts on the S3 and am just about to fit a set to the S2, I can post photos if anybody is interested, they come complete with diff output shafts. Bought from Jeff at JAE whom I can't recommend highly enough.
PostPost by: Spyder fan » Tue Aug 13, 2013 10:03 am
Plus one to that.
Do I need a comfortable chair, a bowl of popcorn and a few tins of Stella?
Kindest regards
Alan Thomas
Spyder fan
PostPost by: StressCraxx » Sat Mar 24, 2018 4:35 pm
Or, to rotoflex or to guibo?
Yes, I'm dragging this out from the dusty archives for those who do not want to convert to CV joints. This conversion is cost effective, actually cheaper than rotoflex by a wide margin.
Here is quote from a vintage racing thread (RMVR).
"We are using these on the west coast for Formula Ford and Formula B (Lotus Twincam 200HP) cars. After multiple failures on new metalastic couplings, the vintage prep shops have adopted the "Guibo" couplings used on Volvo and BMW for halfshafts.
Just went through this exercise again, so posting links to suppliers:
Donuts: Volvo driveshaft guibo from FCP Euro, Febi/Bilstein P/N 1220843, $44.89 each, (2) https://www.fcpeuro.com/products/volvo- ... em-1220843
Spacers: 7/16" bore, 7/16" wide shaft collars from Fastenal, SKU # 33373, $1.07 each (6)https://www.fastenal.com/products/details/33373
Shims (to reduce 12mm sleeves in the donuts to ~7/16"): 15/32" OD, .015" wall brass tubing, Specialty Metals #138, Thompson's Hobbies and Crafts, 1585 Wadsworth in Lakewood, ~$3.80/ft; also available at Ace Hardware stores. Need (12) pieces cut to 1.2" length, so buy 12" two sticks."
Original post: https://www.tapatalk.com/groups/rmvr/rubber-axle-donuts-t3945.html
John Anderson Racing in Sonoma uses specially fabricated spacers that spread the tension and torsion loads. I will see if I can get the info and cost.
All of the above is provided at your own risk.
Dan Wise
StressCraxx
Previous
