Any advice welcome on fitting cv driveshaft conversion
PostPost by: rgh0 » Thu Aug 15, 2013 12:31 pm
The information on the drive shaft lengths was posted a while ago, as I remember I contributed the lengths I used for my Elan and Plus 2. I had a quick look but could not find it and have to get up at 4 am tomorrow so I will leave it for someone else to find now :D
PostPost by: miked » Thu Aug 15, 2013 12:32 pm
Chris,
If you are talking about the total length of the drive devices, I have them.
S4 Elan = 310 mm long
Elan Plus = 386 mm long
These were taken from cars at unladen ride height (on their wheels). On my back with a tape! These are the measurements from the faces of the diff output (3 ear) to the hub shaft shaft (3 ear). I have no doubt there will be some differences over various cars with chassis and bone dims.
Mike :)
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked
PostPost by: miked » Thu Aug 15, 2013 12:36 pm
Chris,
I take it that you know the benefit of short stroke rear damper inserts to limit the droop and acute drive gear angles. TTR does them. Mike
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked
PostPost by: AHM » Thu Aug 15, 2013 5:23 pm
Depending on the CV joints you are using they are right on the limit of articulation at full droop.
The length of the shaft depends slightly on the thickness of the adapter. with 13mm adapter plates I have a 300mm shaft - it pays to have a trial fit.
recent discussion
lotus-gearbox-f37/rotoflex-not-rotoflex-t26435.html
Details for adapter and Rohan's very useful input
elan-mods-f31/elanmac-conversion-t24920.html
AHM
PostPost by: Chris » Thu Aug 15, 2013 6:38 pm
Thanks for the info John.
Just what I needed, at least I can continue to use my car whilst I do the shafts.
Thanks again.
Chris.
PostPost by: Chris » Thu Aug 15, 2013 9:12 pm
Hi Vernon.
When I get the splined shafts made and fitted, I will try to provide some photos with explanatory write up, it may be of use to someone. I made adaptor plates were made from steel, the reason for this was I didn't like the idea of my car being propelled by six 8mm bolts screwed into aluminium, and also I had the steel shaft to hand.
Cost wise so far 4 core plugs ?8.99, Counter bore cutter ?10.73, 12 splined studs ?17.00, 4 Stahltec 100mm cv joints complete with boots, bolts, gaskets, grease, circlips, and a two year warranty ?79.87 for the four. Total so far is ?116.59. I estimate the splined shafts will cost around ?20.00, and protective plating on the adaptor plates ?35.00 inc vat. Grand total ?171.59. Much better than ?600.00. The only machines required so far has been a lathe and a pedestal drill.
Best wishes
PostPost by: Chris » Mon Aug 19, 2013 9:03 pm
Hi Mike.
Sorry for the delay in acknowledging your advice regarding short stroke dampers, and also the total shaft lengths. I intend to take a look at my dampers, if they are leaking, or not working properly I will fit short stroke units. If they are ok, I will investigate shortening of the centre rod, and re threading to effectively shorten the stroke and hence the droop in case of any angular locking.
Blue Skies
PostPost by: billwill » Mon Aug 19, 2013 11:06 pm
Shortening an existing damper will in my opinion be a rather difficult job. Thats a bar of toughened steel in there about an inch in diameter. You would have to dismantle it completely and do the work on a big lathe.
PostPost by: john.p.clegg » Tue Aug 20, 2013 6:01 am
Chris and John
Seeing as both of you have +2s I dont think you will need reduced damper travel...
John :wink:
PostPost by: miked » Tue Aug 20, 2013 10:09 am
John,
When I made the suggestion about the short stoke dampers I had the Elan more in mind (than the Plus 2) but judging by the instructions that I was given about fitting CV's to a Plus 2 (with less droop), I was told not to let CV joints droop at all. They would be damaged. I could not accept this so stuck with sliding spline UJ joints. I continue to have no problems with them. Just my opinion that getting rid of excess droop is a good thing given the option of worn out dampers.
Chris, Good luck with your CV's. Having talked with manufacturers they all seem nervous about quoting actual maximum working angles of droop. Nice to see some finished photo's.
Mike :)
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked
PostPost by: john.p.clegg » Tue Aug 20, 2013 11:44 am
Have you a "baby" as well as a Plus2 ?...
John :wink:
P.S.
" Just my opinion that getting rid of excess droop is a good thing given the option of worn out dampers.".....I'm sure Colin put the springs and dampers at each corner for some reason?...He was not a man to waste metal... :lol:
PostPost by: miked » Tue Aug 20, 2013 7:42 pm
John,
Yes, ongoing project car S4 FHC, nearly ready. Hope to try some hill climbs.
Re: Colin and wasting the metal, very true. Just following what the race boys are doing as lots have had droop limiters with straps before the short shocker came out. It seems logical although I don't know enough technically to say more.
Mike :D
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked
PostPost by: Chris » Sat Nov 02, 2013 6:42 pm
DSC_0766.jpg and
Hi everyone. I have submitted a pair of photos of my homemade drive shafts, as requested. They started life as VW Passat shafts, and were cut to length then the cut end was splined and grooved to accept the new CV joints and circlips.
I assembled them on a rough and ready jig to represent the car. I have lost track of the total cost, but somewhere around ?200.00.
PostPost by: KevJ+2 » Sat Nov 02, 2013 7:16 pm
Chris, fantastic job! I'm sure if you were to sell them at an identical price to 4 rotoflexes & bolts,
you would sell them easily. I for sure would give you an order as it's a job I have to do. Kevin.
KevJ+2
PostPost by: Chancer » Sat Nov 02, 2013 8:02 pm
Result!!!!
How did you machine and heat treat the splines?
Chancer
PreviousNext
