Difference of Elan and Cortina manifolds/headers
I bought a second hand 4-2-1 manifold from a forum member but when fitting it the exit pipes seemed to point slightly downwards and I to strain all the pipes into the Y-piece to align it with the tail pipe. I believe this tension is making the whole car noisy and vibrate as was the case with a harsh FHC someone once asked me to assess.
I seem to remember seeing, but can't find, an item saying that the Lotus Cortina manifold was slightly different so do I have a manifold from a Cortina?
Meg
The Cortina exhaust manifolds I have seen are very difference to an Elan's due to the larger gap between engine and body on a Cortina. This enable the 4 pipes to come out and flow back and down with more gentle bends than required by the tight gap between the block and sub frame on an Elan.
A Cortina exhaust would not fit in an Elan.
Thanks as always, Rohan, that seems rather obvious now!
I wonder if it was the Europa TC that was different.
Meg
The reason for the exhaust droop has become clear: the gearbox mount has perished and so the whole power plant is tilted!
St Wilkins will have a replacement in a month (it's the early type) but meanwhile I've stuffed in some old bits of rubber to hold the gearbox off the chassis where it was graunching.
Meg
Quart Meg Miles wrote:The reason for the exhaust droop has become clear: the gearbox mount has perished and so the whole power plant is tilted!
If I recall correctly TTR do a conversion bracket to fit the later style gear box support to the early arrangement.
For what its worth
rgh0 wrote:If I recall correctly TTR do a conversion bracket to fit the later style gear box support to the early arrangement.
For what its worth
As the last one must have been fitted in 1990 I guess I'll not bother; but thanks.
Meg
