Removing Exhaust Headers Plus 2
Apologies for dumb new owner question, but search was not my friend in this case.
Working on a Plus 2 with after market headers 4-2-1 (so they break down into two separate pieces when removed from the heads).
How do I get the darned headers out of the car?
The only way that I can currently see is by removing the header side engine mount and before I do that, I wanted to see if I am missing an obvious alternate route.
Is there a simple solution here that I am missing?
Thanks very much.
Nick
Thanks very much.
Nick
Nick Baxter
1970 Plus 2S (Federal)
1969 Plus 2 (UK) - sold
- nwbaxter66
Place a jack under the oil pan with a board between the jack and the pan to spread the load. Then, as you have guessed, remove the motor mount. I will hazard a guess that you have removed the Y piece between the header pipes and the exhaust pipe. Wiggle a bit, and things will come apart.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
Thank you very much... I am now looking forward to Wednesday night (:
Nick Baxter
- nwbaxter66
Nick
Make a mental note how they are removed , it will help with re-assembly...that's just as tricky....
Imho keep the studs but while you're there fit new studs assembled with copperslip.
+ new brass nuts and lockwashers.
- alan.barker
some of us use cap heads ( much easier with a ball headed allen key than a spanner/socket ) and if you want to do the job 100% , helicoil while you're in there..
If you need extra wiggle room you could try removing one bolt from the engine mount under the carbs. This should allow easier/more movement of the engine as it can rotate on the other mount.
Just remember it is possible you just have to find the magic sequence that gets them out...
- mbell
(: ... and patience
I think that the engine mount trick should give me the space I need.
N
N
Nick Baxter
- nwbaxter66
Thanks to all the advice, the angle grinder was warmed up, new disc, but was not needed.
Removed Clutch Slave Cylinder and Engine Mount, with oil pan supported as described, removed alternator and top radiator hose and both header pieces came out from below with minimal cursing and verbal persuasion.
Thanks for the assistance, not sure that I needed to take off the alternator and I could have created more room by removing the sway bar and chassis brace but that was unnecessary.
I am sure that the reverse will not be as easy (: But at least everything will be nicely clean while doing that job.
Nick
Nick
Nick Baxter
- nwbaxter66
Blimey, I've never taken them out from underneath, food for thought though.
- AussieJohn
AussieJohn wrote:Blimey, I've never taken them out from underneath, food for thought though.
You should be all right in Oz, your cars are already upside down.
Meg
