How to mount an exhaust system with a Lotus 5 speed box
PostPost by: gjz30075 » Tue Sep 05, 2017 6:11 pm
So, with the 4 speed piece (pictured) having gone away with the installation of the Lotus 5 speed box,
what's the recommended way to mount the pipe at that point?
26f0010s.jpg and
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: mbell » Tue Sep 05, 2017 6:34 pm
On the 5 speed +2 it simple, there no bracket. The center pipe just fits between Y and back box. There is also very little clearance between center pipe and gearbox, care is needed when fitting to get any clearance at all.
PostPost by: gjz30075 » Tue Sep 05, 2017 7:24 pm
Thanks much! Less fab'ing and sourcing of parts, so I can move on. You're right, the clearance between the gearbox case and pipe is pretty tight.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: mbell » Tue Sep 05, 2017 8:37 pm
The ultimate implementation of "Simplify and add lightness"....
I keep pondering if it would be a good idea to trim some of the cooling fins on the bottom of the case. As think they probably acting more as heating fins with how close the exhaust is.
PostPost by: john.p.clegg » Tue Sep 05, 2017 11:28 pm
I had to apply a little heat and stick a fork leg stanchion in it to "set" the pipes away from the gearbox.
John :wink:
