exhaust pipe frustration -Bender needed in Colchester
PostPost by: RichC » Thu Sep 01, 2016 8:18 am
was on the phone to Susan Miller yesterday asking if by any chance the SS system she supplied for my early +2 was mismade (SSL019).... apparently they all have the same 30degree kink both ends ...the only thing is both my original mild steel transverse exhaust box and stainless steel box have 45 degree bends!! .
It seems extraordinary to me .
anyhow seems the most expedient solution is to find a pipe bender locally to me to to put a bit more of a bend in and I haven't yet found anyone in colchester area. Any suggestions ? I've tried googling 'custom exhausts' but nothing comes up locally
RichC
PostPost by: elanman999 » Thu Sep 01, 2016 9:17 am
You could use the cut and weld technique. Nowhere near as neat but would get you out of a hole and you only need to find someone who can weld SS.
elanman999
PostPost by: S3FHC » Thu Sep 01, 2016 10:18 am
can you google steel fabricators in Colchester area?
It would be better to bend than to cut/weld but you may not have enough pipe beyond the bend to hold it in the machine?
S3FHC
PostPost by: TroonSprint » Thu Sep 01, 2016 10:55 am
I had the same issue. I found a small exhaust fabrication business near me and he bent the pipe on his machine for no charge. It only took a couple of minutes. Take the old pipe with you as a pattern. You need to find a business that actually makes exhausts rather than one that just fits them. Most of their work will be putting ridiculously large back boxes on Clios and Corsas!
TroonSprint
PostPost by: TroonSprint » Thu Sep 01, 2016 11:02 am
I've found Powerflow Exhausts at Ipswich, Unit 3 Poplar Hall, Elmsett Airfield, IP7 6LN. Telephone 01473 209210. And also Demand Engineering Ltd, Lewis Farm, Pettaugh Road, Stonham Aspal, Stowmarket, Suffolk. IP14 6AU. Telephone 01473 890820. Both have web sites.
https://www.powerflowexhausts.co.uk/dealer
http://demandengineering.co.uk/
TroonSprint
PostPost by: Bud English » Thu Sep 01, 2016 3:19 pm
Sad state of affairs when a manufacturer puts a bend (kink?) like that one in a new product whether the angle is correct or not. For what the get for SS exhaust systems you'd think they could afford a tubing bender that does a clean job.
Bud
1970 +2S Fed 0053N
Bud English
PostPost by: TroonSprint » Thu Sep 01, 2016 5:56 pm
Too right Bud. Poorly made.
TroonSprint
PostPost by: Elseezed » Thu Sep 01, 2016 7:33 pm
My early +2 s.s. exhaust link pipe did not marry either. I used the original steel link pipe to join the s.s. Silencer to the manifold. When I get the car running I will take it to a local exhaust firm in Rochdale to get the s.s. link pipe fitted. I'm with you all, parts should fit.
image.jpeg and
Early+2 ill fitting link pipe
PostPost by: el-saturn » Thu Sep 01, 2016 8:09 pm
any proper mechanic with the regular equipment can bend it for you - rocket scientists make rockets! sandy
PostPost by: RichC » Thu Sep 01, 2016 8:18 pm
OK so spoke to SS exhausts today and they said Susan Miller's the oracle .... So i am the one who now volunteers to tell Susan / SS that their pattern for early transverse exhaust is WRONG !
lovely lady from SS exhausts said they'd had no complaints up to now ... i'm so glad I'm not alone. perhaps some good will come of this and the inheritors of our early +2s will thank me for the intervention
RichC
PostPost by: RichC » Thu Sep 01, 2016 8:24 pm
oh and thank u Mike , I was looking for a place called ICI thru a friend , and it's actually ISC as u have found it !
bloody miles away out in the sticks but it's the closest at 40mins away .
Rich
RichC
PostPost by: elanfan1 » Thu Sep 01, 2016 9:10 pm
Any good?
image.jpeg and
PostPost by: TroonSprint » Thu Sep 01, 2016 9:29 pm
It's odd one's perception of distance. Living in Scotland I would consider a 40 minute journey to be almost next door. That's closer than for me to visit Glasgow which I do frequently.
TroonSprint
PostPost by: Elseezed » Fri Sep 02, 2016 9:10 am
image.jpeg and
image.jpeg and
You can see when the link pipe was connected the silencer pipe pointed downwards. The manifold end needed about 10 degrees more to align.
Hope it helps, Les
PostPost by: Peter +2 » Fri Sep 02, 2016 6:57 pm
I have the same problem.
My centre pipe came via PM and I have put up with the tale pipe pointing down ever since.
propshaft-removal-1..jpg and
I had to cut my old centre pipe off and disposed of it before I new I had a problem.
I need help too so do let me know if you resolve the issue.
Peter
1968 +2 BRM
Peter +2
Next
