Exhaust fumes
Good afternoon guys, I hope someone can help with a problem I'm having on a 72 +2,I'm getting excessive exhaust fumes into the boot/trunk so much so that any thing in the boot smells of h c .things I've done/checked are as follows
Replaced boot seal,adjusted spring for latch, put talc powder on seal top to check if it's touching boot lid.
Replaced rear lamp gaskets
Sealed bumper bolts,boot board hardware
Checked exhaust for leaks and boot floor
The only thing I'm not sure about is that i've had problems with the exhaust in the past in as much that I've had a few +2 in the past and collected many parts inc a couple of stainless steel exhaust systems,I think I had a 5speed y piece or I fitted it upside down or something because the system would not run straight down the chassis,I sorted that out with another one,I had 2 centre pipes when laid on top of each other I was approx 2inches longer, so I fitted the rear box on to its original mountings and modified one to fit(cut it),the thing that may be wrong is the tailpipe sticks out about 2inches past the rear bumper,looking at pics of others this seems normal,could I cut shorter? Or am I barking up the wrong tree,the engine runs well but I havn't had it on a emission analyzer but don't think the fumes should get in no matter what,any ideas guys
- p.faurie
This is a very common problem. Rohan's suggestion is good. I recall a friend taking this approach with success. His extension was longer than two inches back from the bumper but he didn't do much experimentation to achieve the optimum dimension.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
When purchased back in 87 as an unfinished project, my +2 came with a new Chris Neil stainles exhaust system, when I finally got round to fitting it, the intermediate pipe was short which meant the tail pipe stopped level with the bumper & I had the same problem of exhaust fumes in the car. I replaced the intermediate pipe with the correct length & the tail pipe is now just under 2 inches past the bumper & no more problems, so I wouldn't shorten yours. The only other thing I can think of, is has someone drilled/cut a hole behind the number plate to gain access to the boot latch after a broken cable ? Not uncommon, even tells you how to do it in the w/s manual
- Orsom Weels
