Replacement exhaust
PostPost by: potleyu18 » Mon May 04, 2015 4:39 pm
Whilst removing the engine for a rebuild i inadvertently broke the exhaust manifold, not a problem as an easy fix with a mig welder. just about to carry this out over the weekend and noticed the connection into the Y piece where it failed the pipe protruded in to the Yoke by at least 40 mm creating a massive obstruction in gas flow.
Not a good situation after spending thousands in the rebuild to hopefully gain some increase in HP.
Question is has anyone investigated what is the best supplier of a replacement manifold and probably the rest of the system as well.
Look forward to anyone's help as looking at Tony Thompson site the cost is likely to over ?800
potleyu18
PostPost by: greg40green » Mon May 04, 2015 8:27 pm
Evening Steve
Just going through the same dilemma myself and have ended up placing an order for a full TTR exhaust system inclusive of fixing kit which is over a thousand pounds inclusive of VAT and post .
My Elan came fitted with a large bore manifold but the rest of the system was standard diameter centre pipe and standard Sprint back box , I could have bought just the centre pipe and silencer from TTR but decided to go all out to compliment the engine spec and build quality.
Expensive but the system as well as other TTR parts always seem to get excellent reviews.
greg40green
PostPost by: Certified Lotus » Tue May 05, 2015 1:12 am
I also just purchased the complete TTR fast road exhaust system for my car. With a new engine build almost completed I wanted the free flow and great sound to complement the engine work that was done. Quality of the parts is very very good.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Certified Lotus
PostPost by: potleyu18 » Tue May 05, 2015 7:31 am
Thanks both for your responses and it looks like the TTR system does the job.
Has anyone bought a system from Profusion Customs as they seem to produce some good products?
potleyu18
PostPost by: tablets32 » Tue May 05, 2015 5:53 pm
I had a complete stainless steel system made and fitted by Powerflow in Queensferry.
My car didn't have the twin cam when I bought so I had a zetec fitted. The guys at Powerflow had the car for two days and did an excellent job. Photos are available in the mods section. It cost me ?575. I have no affiliation to Powerflow or any of its subsidiaries.
Keith
tablets32
PostPost by: adigra » Wed May 06, 2015 12:30 pm
I fitted the full TTR fast road system last year. The gain in performance at higher revs is noticeable both on the rolling road and on the real road. Rolling road showed that my 420 spec engine was being choked up by the standard exhaust above 5300-5400 RPM. Fitting the TTR exhaust has really let it breathe.
Fitting the TTR system can be a bit tricky due to the equal length pipes coiling towards the bulkhead, and the chassis cross brace restricting access at the bottom. My mechanic had to cut, and later reweld the brace to fit the system, but later on Spyder replaced it with a removable one.
My car banged and popped quite a bit after the exhaust change, but after a session on the rolling road it's now as nice as ever, albeit noticeably louder.
1967 Elan S3 S/E FHC
adigra
PostPost by: Certified Lotus » Wed May 06, 2015 11:38 pm
Adigra, did you need to make any changes to the standard frame to fit the fast road header?
Glen
Certified Lotus
PostPost by: prezoom » Wed May 06, 2015 11:55 pm
What is the outside diameter of the tubes on the TTR Fast Road header?
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
prezoom
PostPost by: adigra » Thu May 07, 2015 2:13 am
Certified Lotus wrote:Adigra, did you need to make any changes to the standard frame to fit the fast road header?
Just the cutout on the chassis rail, which is usually needed for most larger bore exhausts. My car already had it from the previous system, and it didn't need enlarging for the TTR one.
I did fit some heat shielding to the footwell as the rear pipe of the manifold comes very close to it.
Aside from that, as I mentioned above, we found it impossible to fit without cutting the cross brace, so fitting a removable one was a great solution.
adigra
PostPost by: PaulFinch » Thu May 07, 2015 3:31 pm
Few weeks ago I fitted a TTR full race manifold (1" 5/8ths O/D) and system.
I didn't cut the chassis brace but it probably would've been easier to.
Ended up removing both engine mounts and the alternator and pushing the engine as far across as possible and it then went in.
Bit of a puzzle!
PaulFinch
PostPost by: PaulFinch » Thu May 07, 2015 3:32 pm
prezoom wrote:What is the outside diameter of the tubes on the TTR Fast Road header?
I believe they're inch and a half.
PaulFinch
PostPost by: Certified Lotus » Thu May 07, 2015 3:36 pm
Paul, did you have the cutout in the frame?
Glen
Certified Lotus
PostPost by: potleyu18 » Thu May 07, 2015 5:23 pm
Hi All,
Appreciate all of the advice many comment on the chassis rail removal i have a Spyder frame fitted has anyone fitted the system with such a frame and if so was this adjustment required.
potleyu18
PostPost by: rgh0 » Fri May 08, 2015 9:56 am
Based on the cutout I needed for my Elan with the TTR race system and the Spyder chassis on my Plus 2 I believe the TTR exhaust would clear a Spyder chassis OK.
PostPost by: PaulFinch » Fri May 08, 2015 12:36 pm
Certified Lotus wrote:Paul, did you have the cutout in the frame?
There was already a small cut out in the chassis from a previous manifold. I enlarged this with an angle grinder.
Next time the engines out I plan to strengthen as per the TTR 26R mods.
PaulFinch
