Fitting exhaust manifold
William
I suppose it depends on which manifold you are fitting. If its the four branch type I have fitted and removed these with the body in place so on a rolling chassis it should be a doddle.
I generally remove the studs from the head and then the two parts of the manifold can be wriggled into place. Once you have supported the engine you may as well remove the whole mount and its spacers, you might be able to leave the studs in place then.
iAN
iAN
Elanman99 - Third Gear
With the body on it makes the job easier if you drill the holes oversize- they never line up. Also, as Ian says, remove the studs, after checking that they all run into and out of the head easily.
On a rolling chassis.. it should just all fall into place.
Pete.
http://www.petetaylor.org.uk
Pete.
When I had my rolling chassis and before I fitted the body, I cut out a section of the chassis around the downpipes as per Gordon Lund's book. I recently had to remove the manifolds and I could do this by only removing the engine mount and without removing the studs. A frustrating job made a lot easier.
- KevJ+2
