Oily goo from exhaust gaskets
PostPost by: John Sharples » Sun Nov 25, 2012 10:45 am
Hello all,
I have some black oily liquid discharging from the exhaust gaskets on three of my twin cam?s cylinders. The engine has just been rebuilt. New valve guides and pistons etc. The oil is clean but the plugs are sooty.
The picture shows a typical ?drip?.
So, my exhaust gaskets are leaking but they are pointing to a problem common to all cylinder whereby unburned,black oil is exiting the engine via the exhaust ports. This became apparent after about 60 miles. The only thing that was not replaced or refurbished during the rebuild was the fuel pump.
Anyone had anything like this?
Oil Drip.JPG and
John Sharples
First Gear
First Gear
PostPost by: Chancer » Sun Nov 25, 2012 11:04 am
Oil that was used to protect the bores, ports etc while the engine was waiting installation?
Possibly Wellseal on the gaskets?
Clean it off and only be concerned if its apparent after 1000 miles or so.
Chancer
PostPost by: robertverhey » Sun Nov 25, 2012 11:33 am
robertverhey
PostPost by: John Sharples » Sun Nov 25, 2012 2:53 pm
Thanks for the responses so far. The exhaust gaskets went on dry.
Robert ? I can?t get to your link on the Lotus Cortina site.
John Sharples
First Gear
First Gear
PostPost by: holywood3645 » Sun Nov 25, 2012 6:37 pm
Try
http://www.lotuscortina.net/
and search from there.
James
PostPost by: robertverhey » Sun Nov 25, 2012 7:09 pm
Might be hard to get to the inner sanctum of lotus cortina forum unless you're a full member. But short answer is... Very similar thread, and seems to happen a bit (happened to me!). Turned out to be the gaskets. They need to be a complete seal. Nothing dire like cracked head or leaking valve guides.... try sorting the gaskets first.
Robert
robertverhey
PostPost by: twincamman » Sun Nov 25, 2012 7:24 pm
try V.W. air cooled 1600 exhaust gaskets --nicht leaken --I also removed the studs and replaced them with cap head bolts and a washer so you can get a little more torque with the allen key --but remember your into aluminium so don't get too enthusiastic ------if you are concerned about that you wil do your nut when the oil filler gasket or valve cover gasket gets weak :lol: :lol: -ed
twincamman
PostPost by: John Sharples » Mon Nov 26, 2012 4:42 pm
I have just taken the gaskets off and indeed 3 were blowing. Thanks to all.
John Sharples
First Gear
First Gear
