S3 rear silencer - Dimensions please
PostPost by: AHM » Sat Dec 03, 2011 12:44 pm
Hi All,
The S3 rebuild continues apace - I will post some pictures shortly.
Today?s pressing question is how much space is there for a silencer under an S3 boot floor - I want to put a straight silencer in as for the S4/sprint but appreciate that won't fit.
I have the S4 in the garage but the S3 is some distance away and came minus the exhaust.
I think that the difference is in the rear valance (please correct me) How long can the silencer be and how long does the tailpipe need to be?
Many thanks,
Simon
AHM
PostPost by: elansprint71 » Sat Dec 03, 2011 1:22 pm
I've never had an S3 but doesn't the exhaust go around the houses before emerging?
No idea if the following comment is at all useful but Tony Thompson sells a glass-fibre silencer "tunnel" (for want of a better word) which allows his fatter silencer to fit and of course would allow a smaller straight silencer too. It's like the one you have on your S4 but deeper.
PostPost by: AHM » Sat Dec 03, 2011 1:27 pm
Elansprint71,
Yep, all round the houses - All round the houses is difficult or expensive, straight is cheap and easy.
I don't want to cut the bodywork - I went off bodywork doing the S4!
AHM
PostPost by: types26/36 » Sat Dec 03, 2011 3:09 pm
AHM wrote:Elansprint71,
Sorry cant get to it to take dimensions as its zipped up in a "Carcoon" for winter :roll:
shed and s3 038 (Copy).JPG and
shed and s3 034 (Copy).JPG and
shed and s3 033 (Copy).JPG and
shed and s3 032 (Copy).JPG and
shed and s3 031 (Copy).JPG and
types26/36
PostPost by: mac5777 » Sat Dec 03, 2011 7:19 pm
Hi Simon,
Brian's last photo is what my original S3 muffler looked like with a wrap around tail pipe setup. The tail pipe caused the muffler to sit lower and drag the ground in my driveway. I replaced it with a larger one that had the inlet and outlet on the same side. The muffler shop welded the other end shut. That allowed the muffler to be lifted up and fit the designed opening much better. The body cavity for the exhaust tail pipe exit is smaller than the S4 opening.
I used a heat reflective insulation shield that protected the fiberglass body. I also attached a larger resonator tail pipe that cut the harsh back off bark without restricting the exhaust flow. It did not cost much and has a great sound.
Pictures are the original, a finished view and shows the full clearance.
I think it was a DynoFlow.
Sarto
DSC00010.JPG and
This was a Dave Bean original designed stainless muffler
DSC00004.JPG and
The tail pipe was rolled up to fit the muffler closer to the axle and up.
DSC13.JPG and
Nothing hanging down.
lotus elan 1966 S3 FHC
36/5785
LHD
mac5777
PostPost by: abstamaria » Sun Dec 04, 2011 12:08 pm
Very neat car, Sarto.
Andy
abstamaria
PostPost by: AHM » Sun Dec 04, 2011 2:43 pm
Thanks All,
I'm assuming that the front edge of the Exhaust is the same for S3 and S4.
What I need to know is the distance from the front edge of the rear valance to the reat edge of the bumper - ie how long is the tailpipe.
Simon
AHM
PostPost by: badback » Sun Dec 04, 2011 9:58 pm
Simon this maybe of some use! The tail pipe is 385mm from its end to the centre of the box, if you need more dimensions let me no. Photos rear box for a late S3
DSC02636.JPG and
DSC02635.JPG and
badback
First Gear
First Gear
PostPost by: prloz » Mon Dec 05, 2011 4:07 am
Hi badback Brian,
Can you tell me where you sourced the S3 silencer ?
Thanks.
Peter.
prloz
PostPost by: mac5777 » Mon Dec 05, 2011 7:50 pm
Hi Peter. When I replaced the original muffler I could only get a stain-less one. I just checked with Dave Bean Engineering and he has them in stock all made up. If you look at Brian's picture, Dave Bean welds on an extension that has another 90 bend and attaches to the main supply pipe. He calls it a S pipe making it easier to attach to the S3's. It cost $295.00.
I later replaced mine with the new system as shown in my earlier post. The shop had my Elan on a lift and placed the muffler on a stand to hold it in place. By not having the S pipe that wrapped around the original muffler they were able to move the new one forward and up for excellent ground clearance. While in place they attached hangers to the muffler and used the original body attachment points. The total installed price was about 1/3 less than an original one. Make sure you insulate the body as it is closer. It may not be necessary but I did it anyway with insulated heat reflective foil with a self adhesive backing. if you look at the photo you'll see I even insulated a portion of the exhaust tail pipe extension.
Hope that helps.
Sarto
Andy, thank you.
36/5785
LHD
mac5777
PostPost by: badback » Tue Dec 06, 2011 12:03 am
Sorry Peter can?t help. I?ve had this for some years, think I got it from Donington auto jumble. This one is for a late S3 the early cars have the extra bend as sarto mentions.
badback
First Gear
First Gear
PostPost by: prloz » Wed Dec 07, 2011 1:16 am
Sarto: Thanks very much for the information :D
Badback Brian: If you decide to sell, money waiting :lol:
Peter.
prloz
