Sprint rear silencer grounding
Can anyone answer a question in relation to the rear silencer fixing points? Sounds simple although I get differing replies. At present I have a rubber strap with two holes attaching both the rear and front fixings on the rear silencer. The manual shows only 1 at the rear fixing and looks like the front fixing is bolted directly to the bracket which is isolated by two small rubber fixings bolted to the body. Is this correct as it appears impossible to bolt the silencer directly to the bracket without fouling the bodywork.
The problem with using two straps is that the straps slide down the slider fixings on both ends of the silencer and the exhaust clamp to the pipe fouls the slightest bump in the road and gets knocked off. I'm guessing the design of the silencer has changed and just wondered if anyone has devised a method of clamping the straps so the silencer cannot slip down.
1971 Lotus Elan Sprint
1963 1071 Cooper S
1963 1071 Cooper S
- Bahamayellow
Post deleted....
S4 DHC
S4 DHC
- oldelanman
Bahamayellow wrote:Can anyone answer a question in relation to the rear silencer fixing points? Sounds simple although I get differing replies. At present I have a rubber strap with two holes attaching both the rear and front fixings on the rear silencer. The manual shows only 1 at the rear fixing and looks like the front fixing is bolted directly to the bracket which is isolated by two small rubber fixings bolted to the body. Is this correct as it appears impossible to bolt the silencer directly to the bracket without fouling the bodywork.
Mike,
Come to the next Lichfield meet on 6th April and I'll show you what to do.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
Hi Brian will see you there
1963 1071 Cooper S
1963 1071 Cooper S
- Bahamayellow
Mike,
Some photographs of my '68 S4 fitted with Sprint muffler can be found here under "S4/Sprint Muffler Mounts":
http://groups.yahoo.com/group/lotuselan ... 20&dir=asc
Colin.
Colin.
'68 S4 DHC
- fatboyoz
