Exhaust headers
Can i buy something as that
in England?
I found some in the US (http://www.rdent.com/), but it is to expensive to send to Europe.
THx you for the help.
in England?
--------------Greetz, Didier -------------The destination is irrelevant, when the journey is in a Lotus![/list]
Didi - First Gear
Have a look at http://www.sjsportscars.co.uk/index.php?mod=10
item SJ036S0004
?166.32
I know Sue Miller also sells Manifolds. You should also give her a call.
http://www.mickmillerlotus.com/lotus-parts.html
Jason
item SJ036S0004
?166.32
Jason
Jason1 - Coveted Fifth Gear
Thx for the answer
Didi - First Gear
Difference between headers and manifolds:
Manifolds- Stock part. Cast iron, large heavy and usually poor flowing. They (mostly) look bad too.
Headers- Tubular, lighter and better flowing and looking. Usually has some thought into the length and size of each tube for better breathing. Almost always makes more power than manifolds and helps with fuel mileage.
That's the difference, I think ...
Didi - First Gear
Technically, they're all manifolds:
2. (Mech.) A cylindrical pipe fitting, having a number of lateral outlets, for connecting one pipe with several others; as, the exhaust manifold of an automobile engine. [1913 Webster]
The single-piece, faster to make, quieter cast iron OEM part is typically called a manifold, while the bend-n-weld tubular manifold is called a header in the USA. Header is an expansion of the hotrod/ street-term, head pipe... as in tail pipe, H-pipe, Y-pipe... head pipe.
Tim Engel
Tim Engel
- Esprit2
I haven't found a British textbook which uses the term "headers" (but someone probably will).
You will find quotes of 'header tank' which is really confusing for the translation.
'Boot' is another one to confuse the not English and has anyone every put gloves in their glovebox??
Jason
Didi wrote:Difference between headers and manifolds:
Technically, they're both manifolds, but this is the way I use the terms to acknowledge the distinction.
And yes, I think that the term "headers" originated over here.
Jim
Temporarily Elan-less
summerinmaine - Third Gear
Just to confuse matters further, in Australia they're called extractors.
Oh and when I bought my 1969 Cortina (deceased estate, bought from owner's widow), there was a pair of driving gloves in the glove box. I keep 'em there. Sort of feels ....right
- robertverhey
Didi wrote:Can i buy something as that
in England?
I am using Tony Thompson Racing large bore equal length manifold, (now ?420) in my Spyder chassised +2S.
It's a very tight fit. I need to assemble the engine, including head, and gearbox on the floor, and install/or remove as a complete unit
68 Elan +2, 70 Elan +2s
Foxie - Coveted Fifth Gear
Just thought some of you folk in the Outer Darkness might like to see that in Murrica we do use the terms separately.
Sorry that there's no Elan in the picture.
Jim
ohhh man ---a Corvair pick up truck based rod REVELL KIT ----WAYYY COOOL -rad - and gnarly man----Barris ???? NO PIN STRIPES???? SO Shaky Jake THE PIN STRIPER must have passed on by this time ---------ed [ Lets see the the Brits figure that out ]
