Exhaust bracket.
PostPost by: FEDUP » Wed Apr 01, 2009 12:29 pm
Hello.
Just fiited the exhaust to 1969+2s all worked out quite well ,the only small problem i have is the gearbox mouting bracket , do you use a flexible strap to the gearbox bracket or is it a fixed mouting from exhaust pipe to bracket .
regards ian
FEDUP
PostPost by: ppnelan » Wed Apr 01, 2009 1:12 pm
I have a rigid mounting as the manifold & gearbox are both rigidly attached to the engine.
:arrow: Matthew
ppnelan
PostPost by: rgh0 » Thu Apr 02, 2009 7:32 am
I beleive the original design was a triangular shaped bracket that picked up a couple of the gearbox to tail housing connection bolts and then a rigid steel tab welded to the exhaust pipe that bolted to the bottom of that triangular bracket.
PostPost by: FEDUP » Thu Apr 02, 2009 9:04 am
Many thanks.
ian
FEDUP
