muffler backfire
PostPost by: frankyb » Thu Oct 09, 2008 9:17 pm
my 69+2 was running fine sine replacing my new webbers last month, drove the car all day fine, parked it for 1hour, the when i started her up the motor was running awfull, minimal respond when giving gas ,and lots of backfie when letting go of the gas pedal. I suspect either condensation in the cap or problem with the gas pump? Would like to here you're opinion.
frankyb
First Gear
First Gear
PostPost by: rdssdi » Thu Oct 09, 2008 10:35 pm
Check the timing. It may be that the distributor was loose and moved or some problem with the rotor.
bob
rdssdi
PostPost by: frankyb » Fri Oct 10, 2008 3:16 pm
problem solved, a faulty sparkplug!!,
frankyb
First Gear
First Gear
