Ugly tail pipe
PostPost by: jeff jackson » Tue Sep 28, 2021 9:19 am
My Stainless exhaust is similar to yours Matt.
exhaust bracket.jpg and
my original bracket did not line up with the hole in the exhaust.
I made a new bracket with four holes instead of two and inside I glassed in a 5mm thick piece of aluminium with four tapped holes for the bolts to come in from the outside. Making the whole arrangement a lot stronger.
This then lined up with the exhaust hole and I bought an original hanger from one of the usual suspects.
For the front part of the rear silencer, I made a bracket from aluminium and used two Powerflex original "Mini" exhaust cotton reels to mount the exhaust to.
The original mounting had always bothered me. especially mounting that rear bracket to such thin fibreglass. In my case it was practically worn through and just about to break off. It's much stronger now and after 28 years of ownership I finally have an exhaust that does not wobble around.
Jeff 72+2
jeff jackson
PostPost by: ovalwin » Wed Sep 29, 2021 12:43 pm
Hi Jeff,
That looks like a really good solution.
Thanks for sharing, I'll see how mine goes but it does make the odd rattle so will take a closer look at some point!
Matt.
Matt
1972 Plus 2S
ovalwin
New-tral
PostPost by: JamesRattenbury » Fri Oct 15, 2021 8:46 pm
Hi Jim, I recently splashed out on a Tony Thompson big bore SS system, looks and sounds amazing, is very well made, but does protrude a bit.
20211003_180505.jpg and
1972 +2S 130/4, rolling improvement project.
JamesRattenbury
First Gear
First Gear
PostPost by: berni29 » Fri Oct 15, 2021 8:51 pm
Hiya
Looks pretty good to me.
Berni
berni29
PostPost by: Fred Talmadge » Fri Oct 15, 2021 11:05 pm
Supertrapp
supertrapp.jpg and
Fred Talmadge
PostPost by: Quart Meg Miles » Sun Oct 17, 2021 10:26 pm
No S2, Fred?
Meg
Quart Meg Miles
PostPost by: Fred Talmadge » Sun Oct 17, 2021 11:26 pm
Quart Meg Miles wrote:No S2, Fred?
Not sure what you are asking. I'm just showing a pic of a Lotus with the Supertrapp muffler that I found online.
Fred Talmadge
PostPost by: Quart Meg Miles » Tue Oct 19, 2021 4:48 pm
I thought you might have treated yourself to it and traded in, that's all.
Meg
Quart Meg Miles
PostPost by: Fred Talmadge » Wed Oct 20, 2021 3:20 pm
Still have my S2 just can't get a pic of it right now.
Fred Talmadge
PostPost by: BRGS » Thu Jun 02, 2022 6:03 pm
C50FFB6D-42C5-4675-A142-7AA51F95F9D6.jpeg and
As I got this fixed I thought i would close out the thread with the result. I had her in with Chris Foulds for various TLC and he made a new bracket, polished the back of the box and fitted a shiny pipe. I like it
BRGS
First Gear
First Gear
PostPost by: The Veg » Fri Jun 03, 2022 11:25 pm
Looks good!
Mrs. Veg has suggested that she thinks that a silencer with dual slash-cut tips would look good on my car. I think it would as long as it was made that way and not a tacked-on accessory tip.
2012 BMW R1200GS
The Veg
PostPost by: BRGS » Sat Jun 04, 2022 5:51 pm
unless your car is a Corsa with a boombox in which case that will look fine :-)
BRGS
First Gear
First Gear
Previous
