Exhaust setups
I hope this helps,
Looking at some maths, and my dyno graph, where peak torque is approx 5000,and rounding cid per cylinder to 97/4, gives a 33.5mm ID requirement for the primary pipes,.
I have no idea what standard lotus tubular version is to compare.
If you go smaller then you increase torque below the 5k peak and off course larger will increase above the 5k peak.
This is simple and doesn't take into account cam timing etc which some equations do, also doesn't give a length. Theres plenty of info available to do this tho.
- pauljones
Certified Lotus wrote:I installed a complete TTR 2? system from headers to muffler (I won?t call it a silencer because it certainly isn?t). Now I have a ?built? engine with 147HP at the crank so the better free flowing exhaust is needed. It?s a bit loud when you push the pedal hard but it goes like stink so all part of the sensory experience.
Here is a short video:
https://youtu.be/dgrl1NBuaWc
that sounds ( and looks) great
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
