Replacing exhaust studs
Have you tried Grub screws? When i fitted my exhaust i used them because they have an Allen key cut out in the end which makes fitting and removing them so much easier.
Having stripped a alloy head with a poorly lined up exhaust manifold in the past i wouldn't use Bolts in alloy unless its helicoiled but if its only getting fitted/removed once in a blue moon it would work.
Grizzly - Coveted Fifth Gear
Pistacchio sprint 72 wrote:Rohan, where can we get quality screws with allen female heads?
I buy mine from the local industrial bolt store. If you search you will find one close to you I think. Use ball ended long allen keys to screw then in
I'm with Rohan on using reduced size headed bolts. Only I use twelve point bolts, rather than socket head cap screws. A 5/16" twelve point socket, with a 1/4" drive extension and wrench will provide adequate torque without fear of stripping threads from the cylinder head.
I also find that the twelve point bolts work wonders for starter securing bolts, as well as those used for the engine mounts. Small wrench, easy access. Twelve point 5/16" and 3/8" sockets are much smaller than their 1/2" or 9/16" equivalent. A twelve point socket on a twelve point bolt offers excellent purchase and easy alignment.
Rob Walker
26-4889
26-4889
Rob Walker
26-4889
26-4889
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
oldchieft wrote:elancoupe wrote:Reduced length stainless studs are available, DBE and RDent are among those who sell them.
Or just use a hacksaw !
Jon the Chief
Prezactly!
I bought a new set of exhaust studs, then I measured how much thread i REALLY needed for the brass nut and its washer. Then I cut the new studs down to that length.
Result, much easier to fit the exhaust manifolds onto the head.
