Coat a new Stainless header?
A good wide band senors is pricey Randy. The dual carb setup would need a sensor on each port to do a correct balance of all mix. A single would only give an average range.
At times with the webers I use a thermal measurement of the tube temperature to see how they are doing one at a time. I have watched an engine builder do this on an engine dyno. You can adjust the mix to get a god temperature on each port.
memini55 - Third Gear
It's a pity ceramic coating hasn't always been available!
Cheers - Richard
Cheers - Richard
- ardee_selby
Margaret, I decided to have my new stainless headers ceramic coated. I had them done in regular silver. I have a set that in the past was done in a very shiny silver that was close to chrome. Now that mine are done, I'm wishing for something in between. !!!! I think the shiny silver is a little too tarted up. The silver isn't bad but just not what I have in my head.
Here is a new question for the forum..................... Can I polish the ceramic coating? I was thinking of using a metal polish and hitting them with the buffing wheel. Is ceramic coating tough enough that it won't polish through the new coating?
Pics to follow.
Frank
Pics to follow.
Frank
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
Famous Frank - Fourth Gear
Famous Frank wrote:Margaret, I decided to have my new stainless headers ceramic coated. I had them done in regular silver. I have a set that in the past was done in a very shiny silver that was close to chrome. Now that mine are done, I'm wishing for something in between. !!!! I think the shiny silver is a little too tarted up. The silver isn't bad but just not what I have in my head.
Pics to follow.
Frank
Sounds about as useful as the old Army practice of whitewashing the coal heap
Beware of the Illuminati
Uhmmm . . . what's wrong with the factory cast manifold . . .
I always thought the cast piece was quieter (a plus for me), cheaper (I already have them) and you can paint or coat them to taste.
I realize they aren't a source of extra horsepower, though.
Am I missing something?
mark t wrote:hello, has any wraped there headers? i did on my austin healey 100 m and it worked out great. i plan on doing the same to elan s2.
thanks, mark
Hi Mark
I used DEI's header wrap on my twin cam's header [ header from RD Ent ]. Before installing the wrap, the heat would literally boil the fluid
in the clutch master cylinder during summer autocross events. After installing the wrap, the heat was significantly less.
have fun
jrwiseman - First Gear
Well let's see if I can post a few pics. 1) the very shiny silver coated original headers, 2) The new Dave Bean header coated in silverl 3) the last 1/2 inch of the tube polished by hand, 4)the O2 sensor bung welded to the collector
- Attachments
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
The shiny ones were done by Evans Performance Powder Coating. Actually, they did both of them but at different times.
http://www.evansperformance.com/
770-888-8818
located in Cumming, GA
770-888-8818
Famous Frank
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
67 Elan Coupe
66 Elan S2 SE
65 Elan S2
65 Elan 26R
69 S2 Europa
06 Elise
67 Barracuda
