Exhaust mods for 5 speed conversion
In preparation for my intended swap from 4 to 5 speed gearbox in the Elan, can anybody provide templates or details of the alterations required to the exhaust system to route around the bulkier +2 5 Sp. gearbox pls ?
All the previous forum articles listed have been checked, but details regards exhaust mods. are Sketchy, perhaps someone knows the details ?
Also, (wrong forum I know !) - the exact dimension from flange to flange, of the +2 converted length Prop shaft ?
Replies accepted with thanks,
Phil.
Phil.
Philip.
UK '72 Sprint DHC
UK '72 Sprint DHC
l10tus - Third Gear
Phil
Memory fading now but I believe a torch and BSA fork-leg stanchions were my tool of choice...while fixed in-situ the two ends of the 2 into 1 "set" a little lower,maybe 1/2"
John,
Thanks for the reply.
I thought you may be someone who may know, as I read your posts with great interest whilst you, Bill and Alex and others were doing this conversion.
My system is Stainless, so I think it may be a little harder to bend ?
Someone on the Forum said they had a template ?
Just wondered if it was something that may be still around?
Do you still have the 5 speed?
What's the chance of taking a few underbody shots for me pls ?
Phil.
Phil.
Philip.
UK '72 Sprint DHC
UK '72 Sprint DHC
l10tus - Third Gear
Phil
I'm on my way to the shed now....
Back
My exhaust system was ( still is ) stainless and moved quite easily with some heat and a two foot pipe..
Yes,still have the five speed and it's getting better by the week,not as snickety-snick as the Ford item but I love it
( I wasn't doing 90 on my way back from Newark Autojumble on Sunday just cruising at 4000RPM )
Here are some piccies,sorry about the oil but had a great weekend
104cm from end to end..
Ignore the lambda sensor..
Mounting plate relieved to allow a little more clearance..
P.S.
Piccie 5
Skid plate welded to Y piece to stop speed humps taking the Mikalor clamp out...
Piccie 5
John,
Great response - thanks !
So the exhaust is basically routed underneath the 5 speed box, by bending the two down pipes towards the offside ?(does this make them an unequal length, for re-mating them into the Y- piece) ?
Did you have to extend them to mate up with the Y-piece ( or cut them off level and add more tube ?
Just wondering how you managed to retain the rear silencer box in its original position?
Did you have to extend the single, central exhaust pipe ?
Thanks ever so for your speedy response!
Phil.
Phil.
Philip.
UK '72 Sprint DHC
UK '72 Sprint DHC
l10tus - Third Gear
No,not the offside just downwards
No,the length is hardly altered
Nothing needed cutting off,plenty of "overlap"
The silencer and middle section is stainless home-made
P.S. Please bear in mind this is from years ago so may be incorrect?
for fitting a TTR line (so non standard) in that configuration, instead of hot bending the 2 downpipes I elected to cut and reweld them after about 20? outward rotation (i.e. away from the gearbox) : some pictures in thread
lotus-gearbox-f37/lotus-speed-gearbox-and-concentric-clutch-t32719.html#p220716
no other modifications required besides cutting to lenght the long central piece
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Just been under the car again to measure the clearance...sump 4 1/2",lowest part of exhaust ( rear mikalor clamp on Y piece) 3 1/2", hence the skid plate..
