Silicone to seal exhausts
PostPost by: Concrete-crusher » Mon Aug 18, 2014 5:15 pm
Hi I have bought a shiny new exhaust system and when asking about sealing the joints was advised to use silicone.
This was a surprise as I work for a silicone manufacture and had not heard of its use in the motor trade for exhausts.
The garage showed me a product that was rated upto 240 deg c , now I know silicone will withstand that as my company manufacture silicone that's rated upto 300 deg c so my question is how hot do manifolds get just after the gases leave the head ?
Thanks steve
S4 ish
Concrete-crusher
PostPost by: delle » Mon Aug 18, 2014 5:58 pm
As far as I know, the temperature at the manifold is 600+ deg C
Delle
image.jpg and
69 S4 DHC
68 S3 FHC
delle
First Gear
First Gear
PostPost by: john.p.clegg » Mon Aug 18, 2014 6:19 pm
I use silicone on a regular basis after being told the same,does a good job of slipping the pipes together and sealing....also O.K. when it comes time to dismantle...
Go for it...
John :wink:
PostPost by: Grizzly » Mon Aug 18, 2014 10:17 pm
I've seen all sorts used to assemble slide over joints in exhausts, the trick is to have a reasonable fit to start with then the paste helps the joint slip over but dries quickly so the exhaust pressure won't push it back off the first time it fires, it also has enough about it to block off gaps sufficiently until the carbon finishes the job on the inside. For me i'd only use assembly paste on Slip joints.
I was always led to believe you shouldn't seal the gaskets on Manifolds for example, if there is a leak its often because the flange is warped and from experience with Turbo cars the flatness of the two mating surfaces are the key.
PostPost by: rgh0 » Mon Aug 18, 2014 10:43 pm
You can use silicone on the join to the head as it is cooled by the head itself and does not get that hot. The Y piece joins generally run to hot for even the hi temp silicone and it burns off and the join then tends to leak. The last join to the rear muffler is normally cool enough again to use silicone I have found.
PostPost by: john.p.clegg » Tue Aug 19, 2014 5:08 am
Off topic..
Delle
Looks like you could do with your carbs balancing
John :wink:
P.S. yes I know it's efi.
PostPost by: englishmaninwales » Fri Aug 22, 2014 6:42 pm
I use Permatex Ultra Copper High Temperature Silicone RTV on collector joints and seems to work well and keep it all gas tight, but as above starting with good fitting pipes.
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
