Which coolant with a new aluminium rad
PostPost by: Bits » Sat Jul 29, 2023 4:51 pm
Which coolant is required please now I have a new aluminium radiator.
S4 Elan with a standard twin cam engine. :D
Bits
PostPost by: lotusfan » Sun Jul 30, 2023 2:42 pm
The answer is Bluecol U Universal.
It's a bit of a worrying question given that you have a standard twin cam engine with an aluminium cylinder head, which anti freeze have you been using before you changed the radiator?
72 Sprint DHC
lotusfan
PostPost by: Bits » Sun Jul 30, 2023 4:59 pm
The engine has been totally overhauled and is as new as the Aluminium rad.
Bits
PostPost by: JonB » Mon Jul 31, 2023 7:41 am
I think the answer is “any normal antifreeze solution will do”. There’s no special requirement that I know of when fitting aluminium radiators.
PostPost by: alanr » Mon Jul 31, 2023 9:33 am
JonB wrote:I think the answer is “any normal antifreeze solution will do”. There’s no special requirement that I know of when fitting aluminium radiators.
Depends on what you call 'normal'?
I would not use a modern OAT based Antifreeze in the engine/radiator in your twincam. The additives in OAT type antifreeze used in modern day vehicles is not suitable.
You need to use a traditional Ethylene Glycol based Antifreeze of which Buecol U Universal antifreeze has usually been the antifreeze of choice in the UK for our engines but there are others similar if you shop around.
Alan.
Currently:-
1971 +2 S130/ 5speed Type 9.
PostPost by: 2cams70 » Mon Jul 31, 2023 9:45 am
"Universal" in my mind usually means can do the job but compromised and not the best tool for the application. Like using an adjustable spanner instead of one of the correct size. Is it any better or worse than traditional Ethylene Gylcol based solutions? It may have an advantage as a top up fluid if you don't know what type of coolant is already in the system but is it really any better when you are doing a complete coolant change? Bluecol U seems to be something other than a traditional anti-freeze.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
PostPost by: alanr » Mon Jul 31, 2023 9:56 am
I was just trying to get over the point that the OP needs a traditional IAT antifreeze which needs to be changed every couple of years is best for our cars.
Inorganic coolant (IAT) works better with the metals used in older engines.
A modern day 'normal' OAT based antifreeze is not suitable
Currently:-
PostPost by: rgh0 » Mon Jul 31, 2023 11:01 am
The modern OAT antifreeze is not suitable for the best protection of copper and solder in the original radiators. The older IAT antifree provides better protection but if using a modern Aluminium radiator I see no reason not to use an OAT based coolant if you wanted to.
PostPost by: 2cams70 » Mon Jul 31, 2023 11:52 am
Yes but these "universal" coolants can be mixed with both IAT and OAT with supposedly no compatibility problems. Surely there must be a trade off?
PostPost by: Rob1n » Fri Aug 11, 2023 9:01 pm
What about waterless coolant what are the thoughts on using that?
Rob1n
First Gear
First Gear
PostPost by: smo17003 » Fri Aug 11, 2023 10:35 pm
Rob1n wrote:What about waterless coolant what are the thoughts on using that?
A couple of previous discussions here:
viewtopic.php?f=39&t=45603
viewtopic.php?f=39&t=29293&start=
1967 S3 FHC
1968 S4 FHC
smo17003
PostPost by: Rob1n » Sun Aug 13, 2023 4:26 pm
Thanks for the links really interesting. With Evans seems more questions than answers. My plus 2 is getting close to being back on the road, I have purchased some of the Evans so perhaps I will give it a go and see if I have any problems. I did have over heating while stood in traffic, but that was before the engine and rad rebuilds, lots of sludge removed from engine when stripped but we will see?
I am always astounded by the amount of and the quality of information available from all on this site.
Rob1n
First Gear
First Gear
