Clutch Problems With Elan +2s130/4. Advice Please!
PostPost by: ed_vh » Sun Sep 21, 2003 6:54 pm
I have an Elan +2S130/4 (1973). It has a problem with the clutch. If the clutch is fully depressed the car goes into gear fine, but as you release the pedal the drive suddenly comes in. It's like an on/off switch rather than a gradual progression from no drive to drive. The car has been unmoved for 8 months.
What can it be,
1. worn out clutch
2. incorrect adjustment of the clutch pedal (clutch needs bleeding)
3. Just out of use and will get progressive with use.
4. ? (any other possibilities)
My feeling is that the clutch pedal action is a bit soft so some seal may have gone in master cylinder or slave (option 2. above), but I can't see how this would give the effect it is.
If the answer is 1. how hard is it to change the clutch? Engine and gearbox totally removed from car?
Any advice greatly appreciated.
Ed
ed_vh
First Gear
First Gear
PostPost by: types26/36 » Sun Sep 21, 2003 7:57 pm
Ed,
I think you have covered all the possible causes but my feeling would be to start at the simplest, as its stood for a while bleed the clutch and reset the adjustment on the slave cyl push rod (slight free play when pulling rod out against the spring)
if this does not help the chance's are you are in for a clutch job, the clutch plate could be contaminated with oil or rust or just simply worn out. To remove the clutch you need to take out the engine although its sometimes easier to remove the engine and g/box as a unit. If it is possible to drive it slight rust contamination on the flywheel/pressure plate may improve with use.
Good luck,
64Elan/72Sprint/J.P.S.Europa
types26/36
PostPost by: SADLOTUS » Sun Oct 19, 2003 10:42 pm
I take it you've checked the level? :mellow: :mellow:
SADLOTUS
PostPost by: dhcelan » Mon Oct 20, 2003 3:45 am
Ed,
I just experienced the same type of clutch problem you discribed on a car that had sat for 10 years. I installed a new master cylinder due to a worn inner sleeve. I also used a rebuild kit for the slave cylinder and adjusted the play per the manual.
I still had the on off at about 1/4 inch off the floor. There is no clutch pedal adjustment. I found that the master cylinder pushrod clevis attached to the clutch pedal had worn the hole where the pin goes through. I removed the master and welded clevis hole and redrilled. (plus a little further out)
It now works like brand new and feels great.
Hope this helps
Randy
dhcelan
New-tral
PostPost by: LaikaTheDog » Wed Oct 29, 2003 8:28 pm
had the same problem , found it was the slave cylinder, it had got a bit grungy over the years, so when I let out the clutch the piston was sitting on a ring of gloop and then suddenly overcoming the friction and meeting the actuator rod further down the bore, so it appeared as it the clutch was on or off, a nice cheap slave cylinder rebuild kit and a good clean fixed it.
LaikaTheDog
PostPost by: ed_vh » Thu Oct 30, 2003 11:43 am
Great thanks for the replies. I have not had a chance to try it yet. Firstly need to get the car ready to run since it's lack of use. Drain old fuel, new spark plugs etc, then will start with simply bleeding it first and work up from there.
Ed
ed_vh
First Gear
First Gear
