clutch pedal soft when engine is started
• Page 1 of 3 • 1, 2, 3
Hi all, I've fitted a new clutch plate and slave cylinder with a Speed bleeder on my +2 and can select all gears (4 speed) when in neutral with the engine off. When the engine is started the clutch pedal goes soft as if it needs bleeding and its impossible to get any gears
This has baffled me, I've been trying the push rod adjustment but no luck
Has anybody else had this problem? Thank you in advance John
- checkrail
Air in clutch slave cylinder needs bleeding.
- alan.barker
You need to push the slave cyinder fully forward so it is hard against the retaining circlip when adjusting the lever arm free play to the Lotus recommended 2 mm value. If the arm is moving around 10 to 15 mm but the clutch still not disengaging then something internally is wrong with the clutch or throw out bearing assembly
The clutch changes in feel depending on whether the engine is running or not? Are you sure? Never heard of that before and can't think of a scenario of how it could happen.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Set the clutch arm to the factory setting. With the engine off get someone to pump the pedal whilst you observe what is going on at the slave cylinder. Then check the same with the engine running, use a ruler or measure of some kind to make sure the push rod is travelling the same amount in both cases. Next observe what is happening in the master cylinder, does the fluid level change in both scenarios, and are there any bubbles being produced in the fluid in either situation.
If all these check out then it looks like an internal problem with the arm or the throw out bearing. Did you just fit a new clutch disc or did you change the the whole assembly, pressure plate, disc and throw out bearing?
Tony
Tony
- tonyabacus
Hi Tony, I just replaced the clutch disc, the slave is new and overhauled the MC, but I think the clutch pedal pressure is not very heavy. I've bled the slave with the speed bleeder several times with no sign of any bubbles, but
I still think there should'nt be any free play on the slave, surely this must affect the clutch adjustment, perhaps I could add an extra circlip?
Thanks John
Thanks John
- checkrail
There is always some free play in the slave mounting in the bell housingof a few mm, some slave cylinders have two grooves so use the grove closest to the bell housing just make sure the slave is pushed full forward when adjusting the lever clearance.
The clutch system is difficult to bleed due to orientation of the bleeder and can need multiple attemps. and is a two person operation unless you fit a speed bleeder to the slave as others have said after getting most of the air out wedging the pedal down with a piece of 2x4 against the seat and leaving it. However you need to be able to get some pressure in the system for this to work.
