Stiff clutch pedal
Last spring when it was time to put my 1969 S4 DHC back on the road, I discovered a puddle of fluid from the clutch master cylinder beneath the car (and onto the footwell carpet).
I decided to renew everything. I am using a 5/8-inch master cylinder from Wilwood, a 3/4-inch slave cylinder from British Parts Northwest and a new steel braided line from Dave Bean.
The clutch pedal comes in very close to the top of its movement and engages/disengages well.
But it takes a whole bunch of pressure to push it...enough that at a traffic light my left leg often begins cramping up and I have to shift to neutral and take my foot off the pedal.
I don't remember it being that hard before I installed the new parts.
The only thing that is different is the steel braided line, but I'm hard pressed to think that can be the cause of the stiffness.
I'm open to suggestions. All will be appreciated. Thanks.
- JerryBoone
The Slave should be 7/8" Dia
- alan.barker
Lotus54 wrote:The slave on mine failed- I found a 3/4” new slave and installed it. ( I do have larger one and now parts to rebuild original). It was stiffer than original, but disengaged better.
I'm not sure if it would disengage too much and if that is good for the Thrust Bearings on the Crankshaft.
- alan.barker
There is a fair amount of ‘slop’ in the pedal/rod area. So I think fine. Engagement is not much different location than before. Eventually I will swap in the new proper one. Although this one claimed to be for Lotus Cortina and Elan. I do not think the throw is that much different, but I also did not measure. It also was not that much different in foot pressure- at least to my uncalibrated leg.
1966 Lotus Elan S3- Benelli motorcycles (various)
- Lotus54
Ok,
For sure the 7/8" dia Slaves are more expensive than the 3/4" dia
- alan.barker
The difference between a 3/4" slave cylinder and a 7/8" one with he same master cylinder is really quite a lot.
The 3/4 bore cylinder has a cross sectional area of .4418". The 7/8 bore is .6013" which is a 27% difference. That's quite a big reduction in pedal weight.
- Phil.C60
If you use a smaller bore slave cylinder the travel of the release arm will be more than when using the correct one. You could therefore potentially over stroke the clutch and damage it.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Thanks everyone. I've ordered a 7/8" slave cylinder. I'll let you know how it works out.
- JerryBoone
It will also lower the biting point and make the action more progressive.....as long as you still get enough clutch clearance. I've found that pushrod length adjustment is quite fussy, needs to have no preload with everything at rest but only the slightest play clearance/play. Best done with the return spring disconnected. Hope this helps.
- Phil.C60
Save the old one and have it sleeved. A spare is always handy.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
