borg and beck clutch
PostPost by: street » Mon Feb 20, 2023 4:23 am
4 SPEED +2; I've found part number HL6231, anyone confirm this is correct?
thanks
street
PostPost by: reb53 » Mon Feb 20, 2023 6:13 am
Not sure if the driven plate, which I assume you're referring to, is the same in a +2 as my Sprint but the numbers I've noted for my car are "Repco R8082W", and the Ford number, ( Capri), 69EB 7550 BA
Ralph.
Napier.
reb53
PostPost by: alanr » Mon Feb 20, 2023 9:09 am
The current numbers for a Borg&Beck clutch:-
Cover and plate kit :- HK6231
Driven Plate only:-
Originally a 203mm driven Plate was fitted and the part number for that was HB1340 but this 203mm plate is no longer available.
The current 215mm driven plate number as used in the cover/plate kit is HB973B.
Hope this helps,
Currently:-
1971 +2 S130/ 5speed Type 9.
