Clutch Slave Cylinder take it out
PostPost by: Helio_s » Mon Aug 26, 2019 12:37 pm
Hi everyone,
I'm new here and I'm french so, sorry for my English.
I start to rebuild my old lotus elan +2.
I've a problem to take out the slave cylinder (clutch).
He's stuck and I don't think so there we have a piston pin.
Don't understand what blocked out the slave.
Any tips to take it out ?
Best regards,
Elio
Helio_s
First Gear
First Gear
PostPost by: Bombay Racing Green » Tue Aug 27, 2019 8:07 am
Hi Elio,
There is a snap ring (circlip). The opening might be out of sight when you are under the car.
Also the previous owner/mechanic may have used loctite on the cylinder. VERY careful use of heat and a large hammer may work. The cylinder will probably be junk at the end.
I removed mine recently. No loctite but the clip was a real pain. I hope it helps.
Pete
1970 S4 DHC
1971 S2 Europa
1968 +2
Bombay Racing Green
PostPost by: JonB » Tue Aug 27, 2019 8:40 am
I recently took mine out. The clip is not a normal circlip with pin holes for a pair of circlip pliers. I had to use a screwdriver with a small hammer to rotate it to a suitable position, then it was straightforward to get off. Once removed, corrosion was holding the cylinder in place, so I drifted it out with a piece of wood and the hammer. It survived, but I may need a new clip.
http://www.lotuselan.net/wiki/QA_-_Clutch_%2B2
Item 26 on the diagram is the clip you need to remove.
PostPost by: types26/36 » Tue Aug 27, 2019 8:47 am
More posts with in this post regarding the circlip and the cylinder.
viewtopic.php?f=37&t=20000
types26/36
PostPost by: Helio_s » Tue Aug 27, 2019 9:25 am
Thanks for all your help.
I was under the car, and I'm not really sure to see a ring, that why I don't understand why is not goint out.
Is an obligation to have this ring ?
May be I need to look better 8)
Helio_s
First Gear
First Gear
PostPost by: 69S4 » Tue Aug 27, 2019 9:32 am
If the cylinder isn't held in by rust you must have the circlip. Otherwise there is nothing to hold the cylinder in place.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69S4
PostPost by: jono » Tue Aug 27, 2019 11:49 am
It's possible the cylinder, being aluminium, may have been 'frozen' in by electrolytic corrosion.
PostPost by: wotsisname » Tue Aug 27, 2019 1:15 pm
in replacing my ring clip, i used a pair of standard circlips (required 2 to stop the slave moving). is there any reason this is a bad idea ?
1968 Elan plus 2 - project
2000 Elise S1 - Sold
wotsisname
PostPost by: jono » Tue Aug 27, 2019 3:29 pm
If I recall correctly, the cylinder needs a small amount of 'float' such that it's able to move slightly in the bellhousing hole before reacting against the clutch lever
PostPost by: ericbushby » Tue Aug 27, 2019 3:32 pm
I used ordinary circlips as well, and they were in stock at my local engineers supplies shop; some years ago now.
Eric in Burnley
1967 S3SE DHC
PostPost by: 69S4 » Tue Aug 27, 2019 4:36 pm
jono wrote:If I recall correctly, the cylinder needs a small amount of 'float' such that it's able to move slightly in the bellhousing hole before reacting against the clutch lever
Mine does have a small amount of float but I've always assumed it was 'good enough' with off the shelf parts - ie a bespoke set up wouldn't have the end float. Now you've got me thinking about whether the end float is there for a reason, and if it is, what is the reason? :?
Stuart Holding
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69S4
PostPost by: Donels » Tue Aug 27, 2019 5:09 pm
I have removed a couple of these. On both once the ring was out it was impossible to remove the slave cylinder due to corrosion. On the first after many attempts, in frustration I just whacked the slave cylinder with a cold chisel around the outside of the ring groove. It fell apart and came out in bits. The second i did the same, 2 minutes max to remove and they're not expensive to replace.
Dave
Elan +2
Elise mk 1
PostPost by: billwill » Tue Aug 27, 2019 5:28 pm
The clip ring has a gap in it and it is made of spring steel.
Item 27 in the diagram below. It is fairly tight against the back edge of the tubular hole in the bell housing. It surrounds the slave cylinder sitting in a groove.
The ends of the gap are squared off and so to remove it you ideally need a circlip pliers fitted with flattenned pins. Rotate the ring around the slave with a pipe grip or tap it with a chisel drift rod, until you get easy access to the gap in the ring.
Get the ends on the circliip pliers into the gap and squeeze gently to expand the ring. You should then be able to wiggle it out of its groove and onto the larger diameter portion of the slave cylinder. Do not expand it more than necessary or you will snap it or weaken it.
Tap it along with a drift until it pushes the rubber cap off the end of the slave and you should then be able to get it and the pushrod and adjusting screw off.
Removing the hydraulic pipes and tapping the open end of the slave cylinder with a piece of wood in between it and a small hammer should then get the slave out of the bell housing.
Getting it back on is the reverse of this procedure :D
PostPost by: RichardHawkins » Tue Aug 27, 2019 8:13 pm
Elio,
I bought the type of pliers that Bill describes from Snap On. A Google search found a few alternatives, but they were all American, I did not find a European manufacturer. As the gearbox and slave cylinder were Ford parts that might explain the use of this type of circlip/snap ring.
Good luck getting it apart.
Richard Hawkins
RichardHawkins
PostPost by: billwill » Tue Aug 27, 2019 10:46 pm
Mine are like these, they have little clamps on the ends so that you can fabricate weird points for the pliers from old nails etc.
https://www.lasaero.com/products/article/A011YSSUT
Next
