clutch hose brackets
PostPost by: milton » Wed Jul 24, 2019 11:06 am
20190724_111737.jpg and
clutch hose
If you have any photographs showing where the clutch hose brackets are bolted to the car can you post them, please, '70 Elan RHD.
Milton
milton
First Gear
First Gear
PostPost by: MarkDa » Thu Jul 25, 2019 12:22 am
Here's the top end as best I can get - hopefully someone else will have better.
20190725_011940.jpg and
Clutch pipe master end
So it looks as if I fabricated a Z shaped bracket to get the union below the wheel arch.
The clearance under the airbox is not great.
The slave end of flexible clips to bell housing iirc with rigid continuing to cylinder.
If you can get bleed nipple upper most then it should be easy enough getting air out.
If you're feeling slush you can buy a braided flexible to go direct from master cylinder. H
MarkDa
PostPost by: Grizzly » Thu Jul 25, 2019 9:43 am
Library google picture (so hope who ever originally posted it doesn't mind me putting it here)
As you can see here the top should be fixed to one of the engine mount bolts. (since the picture was taken i found the clutch line fits better using the lower engine mount bolt)
p1030652.jpg and
clutch.jpg and
One thing you have to address with the clutch slave is the proximity to the exhaust manifold, to do this most people fit a small heat shield to the back of the slave cylinder and wrap the hard pipe with heat insulation. Doing this will substantially prolong your clutch slave cylinders life and will prevent any unwanted clutch issues on hot days.
Link to examples..... viewtopic.php?f=31&t=35663&start=15
Some thing else to think about is fitting a remote bleeding pipe and fix it some where more accessible.
PostPost by: MarkDa » Thu Jul 25, 2019 11:55 am
That's much better than the arrangement on my car - I've had it since 1982 and put it back where it came from when I rebuilt it.
Not easy to get at with carbs on so it's going to stay there fo a while!
MarkDa
PostPost by: Grizzly » Thu Jul 25, 2019 12:59 pm
I couldn't remember where i had seen the the engine mount assembly picture but just remembered, the guy who originally dis-assembled our elan was a test engineer so had the habit of drawing little diagrams of everything he took apart (thought getting a a4 binder full of little drawings was a bit ott at the time but it's surprising how often it's come in handy).
This is the page i remembered.
engine-mount.png and
PostPost by: types26/36 » Thu Jul 25, 2019 1:01 pm
Here is a couple of pics where the brackets bolt on.
clutch-pipe.jpg and
clutch-pipe-2.jpg and
types26/36
PostPost by: MarkDa » Thu Jul 25, 2019 1:11 pm
It's great to have a full if sketches.
I suppose nowadays people reach for their phone and take photos to aid reassembly.
MarkDa
PostPost by: Grizzly » Thu Jul 25, 2019 1:22 pm
MarkDa wrote:It's great to have a full if sketches.
To be quite honest i was surprised when i started going through the paper work and found hundreds of pages of diagrams of parts, they are labeled between 72 and 82 which is the period the car was on the road. I don't know if he had the worse memory or just a bit ott on making sure every washer went back in the same place. Either way it really helped me assemble the boxes of bits.
PostPost by: MarkDa » Thu Jul 25, 2019 1:44 pm
30 or 40 years ago that's what you did, especially if you know it'll be a while before you reassemble.
Nowadays that means tomorrow for me!
MarkDa
PostPost by: types26/36 » Thu Jul 25, 2019 2:09 pm
Reputedly an old Chinese proverb says ?The faintest ink is more powerful than the strongest memory? :D
types26/36
PostPost by: pharriso » Thu Jul 25, 2019 6:38 pm
types26/36 wrote:Reputedly an old Chinese proverb says ?The faintest ink is more powerful than the strongest memory? :D
That's very good! :D I use my cell phone to take pictures before I pull something apart... saved me a few times :roll:
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: Bigbaldybloke » Sun Aug 04, 2019 3:36 pm
I bought the long flex hose from One of the well known suppliers but in addition I used a banjo fitting on the slave cylinder to keep the pipe further away from the exhaust. It appears to fit nice and neatly. Don?t be fooled by the first picture, due to the angle it was taken at it looks as if the clutch pipe goes into the cylinder head breather pipe, it doesn?t!
8cc872e9-7589-4513-8cc4-c5d6c311011b.jpeg and
6ce53142-656a-4006-b8d9-f2719bc77e07.jpeg and
