Pedal box - limit screw for clutch master cylinder pedal
PostPost by: dick+2130/5 » Thu Nov 08, 2018 5:03 pm
Dear All,
I have the pedal box out to change the seals in the clutch and brake master cylinders. When refitting the clutch pedal clevis pin to the push rod I noticed this adjusting screw for the first time. I have wound it out about 10 mm from its original position - hard to move, and looked like it might have been Loctited originally.
Can anyone hep me with setting advice please ?
--- or is it redundant ? no mention in the +2 workhsop manual.
Thanks and Best Wishes,
Dick
p1240218.jpg and
Pedal box- late 1973 +2S 130/5 - exterior - adjusting screw in opposite corner to brake switch
p1240216.jpg and
Pedal box interior - screwdriver points to adjusting nut
dick+2130/5
First Gear
First Gear
PostPost by: JonB » Thu Nov 08, 2018 5:47 pm
Yes, it limits the clutch pedal "fully pressed" position, so that the master / slave cylinder doesn't get over actuated. Definitely not redundant.
