Clutch pedal travel
PostPost by: saildrive2001 » Fri Mar 09, 2018 7:47 pm
I have approx. 1/16 to 3/32 of an inch free play at the rod on my clutch pedal. I think that I used the old rod & replaced the new one when I rebuilt the car but cant really remember for sure. Is there any other explanation as to why I have this play? The clutch operation is fine but with the play the pedal rattles.
Keith Marshall
saildrive2001
PostPost by: Chrispy » Fri Mar 09, 2018 10:25 pm
Could be wear in the clevis or an elongation of the hole in the pedal. I had to weld mine up and re-drill the pedal.
Elan +2 #0245
Exige S2 Supercharged
Chrispy
PostPost by: Foxie » Sat Mar 10, 2018 2:53 am
saildrive2001 wrote:I have approx. 1/16 to 3/32 of an inch free play at the rod on my clutch pedal. I think that I used the old rod & replaced the new one when I rebuilt the car but cant really remember for sure. Is there any other explanation as to why I have this play? The clutch operation is fine but with the play the pedal rattles.
I have fitted both my clutch and brake rods with a threaded and adjustable clevis. I can adjust free play to a minimum.
It also helps to have a removable cover on the top of the pedal box to permit access :)
68 Elan +2, 70 Elan +2s
PostPost by: saildrive2001 » Sat Mar 10, 2018 4:35 am
Where did you get the adjustable clevis?
Keith Marshall
saildrive2001
PostPost by: gjz30075 » Sat Mar 10, 2018 11:34 am
Keith, I'm pretty sure I got mine from Pegasus but now can't find it on their site. Speedway carries something
similar
https://www.ebay.com/itm/Speedway-Motor ... -1&vxp=mtr
Just cut off the clevis from the original pushrod and die cut some new threads to accept the threaded clevis.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: Orsom Weels » Sat Mar 10, 2018 12:12 pm
There should be a small amount of free play to ensure the pressure is off the hydraulics & you should have a light return spring from clutch pedal to pedal box to stop any rattling.
Regards, Tim
Orsom Weels
PostPost by: miked » Sat Mar 10, 2018 1:04 pm
With Chris on weld up and redrill. Done mine. Bit of a faff but best pedal I have had on an Elan. Mike
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked
PostPost by: saildrive2001 » Sat Mar 10, 2018 2:02 pm
Tim, I don't have a return spring & I don't see anywhere where it would attach. I am the only owner of the car & when I restored it I was careful to store any parts I took off together, so I don't believe I ever had a return spring on the clutch pedal. The workshop manual doesn't show one on the clutch pedal only the brake pedal.
Keith Marshall
saildrive2001
PostPost by: ericbushby » Sat Mar 10, 2018 3:00 pm
Keith,
I have about the same free play as yours and I did not notice any wear when it was stripped down.
Perhaps there is nothing wrong with yours.
Mine is a RHD Series 3 and has a return spring on the clutch pedal.
There is a small hole for the spring in the pedal, just above the clevis pin, and two holes in the top bracket where the pedal assembly is fixed to the body. One for each spring.
The springs seem identical.
Hope this helps
Eric in Burnley
1967 S3SE DHC
PostPost by: gjz30075 » Sat Mar 10, 2018 3:23 pm
Keith, here's a pic of one end of the return spring, circled in red. The other end gets hooked to a tab, of sorts.
handbrake.jpg and
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: Orsom Weels » Sat Mar 10, 2018 3:51 pm
Hi Keith,
I don't remember any Elan I've worked on not at least having the holes to attach a spring to on both pedals, even if the springs were missing. My series 4 certainly has both clutch & brake pedal return springs, as does my friends series 3. Basically as Eric describes.
There's a few pictures of them in this thread lotus-chassis-f36/pedal-box-photo-t29885.html
Regards, Tim
Orsom Weels
PostPost by: types26/36 » Sat Mar 10, 2018 5:59 pm
The S1/S2 Workshop Manual shows two springs (#70) and so does the early parts list.
The later Elan parts list only shows one spring but lists as having two.
I also have never seen an Elan with only one spring but I have never looked at a LHD car.
1-clutch-spring.jpg and
2-clutch-spring-2.jpg and
3-clutch-spring-later-parts-list.jpg and
4-clutch-spring-later-parts-list.jpg and
types26/36
PostPost by: saildrive2001 » Sat Mar 10, 2018 6:10 pm
Thanks for all the replies, I guess I now have to source a spring which should solve my problem. I will have to do a thorough search of my old parts to see if the missing spring is there. Failing that, any help in sourcing one would be appreciated, especially if in NA.
Keith Marshall
saildrive2001
PostPost by: types26/36 » Sat Mar 10, 2018 6:24 pm
s and j have them but sounds a bit expensive for a spring, you can probably source a spring from your local hardware store.
https://www.sjsportscars.com/parts-and-accessories.htm
s-and-j-spring.jpg and
types26/36
PostPost by: elanner » Sun Mar 11, 2018 12:45 pm
I purchased a couple of springs from Ray at R . D. Enterprises a few years ago.
cron
