Elan Plus 2 MT75 Slave Cylinder Bleeding
Hello,
So, I finally got a it more 'time off' to replace the clutch master cylinder on my Plus2 - cutting the top off the pedal box made life so much easier. New cylinder in, great. Car up on axle stands, great. Can't find the slave cylinder, strange...Tracing the hydraulic pipe it travels inside the bellhousing so a bit of online reading points me in the direction of there possibly being a concentric clutch slave cylinder somewhere in there, ideally with an external bleed nipple somewhere.
With the MT75 Spyder conversions where would the best place be to start looking for this magic hidden nipple...? I've had a good look and rummage around under there but can't find anything that obvious yet.
Any pointers welcomed
Joe
Joe
1974 Lotus Elan Plus2 130/5
1962 Daimler Dart
1968 Jensen Interceptor Mk1
1969 Rover P6 3500
1972 TVR Vixen 2500
1972 Maserati Indy 4.7
1980 VW Camper T25
1988 Toyota Hilux Pickup
1996 TVR Cerbera 4.2
2003 Smart Roadster
1962 Daimler Dart
1969 Rover P6 3500
1972 TVR Vixen 2500
1980 VW Camper T25
2003 Smart Roadster
- yosini
ok, search over - but I was not expecting that....for future reference and for anyone else looking in vain. It's on the opposite side to where the hydraulics enter the belhousing behind a well disguised rectangular grommet shielded partially by the exhaust. Great, now let's see if it will bleed!
Joe
Joe
- yosini
Joe, here are a couple of pictures that might help with your description. Item 1 is the hydraulic line and item 2 is the bleed stem. Note the bell housing orientation in the first picture, which shows the bleed opening is on the left side as you found out; the bell must be on it?s side in the other picture.
Here is a link to the service manual for the MT75. The Scorpio web site also has the parts diagrams.
http://www.fordscorpio.co.uk/manual/man ... erhaul.pdf
Question. Does yours have a rubber piece to fill the rectangular hole in the bell? Mine never had something to cover the hole, and not sure where to get something. Transmission is out righ now so would be a good time to add something.
HTH
Stu
HTH
Stu
Stu
1969 Plus 2 Federal LHD
