Proper clutch disc for a Lotus 5 speed?
Before I have the hub machined down 5mm, per the Lotus Bulletin, please take a look at the pics. It's
a 8 1/2" disc that I got some time ago and I've always wondered about the small amount of friction area.
The 5 speed disc (alleged) is sitting on the Lotus Bulletin in the pics.
I measured another 8 1/2" disc I have (not from my car) and the friction material on it considerable larger.
So, is this a proper disc for a 5 speed? Splines fit fine, btw.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
Greg
I wouldn't worry about 1/32" less friction material .
Greg
I'd check the OD's , are they both 8 1/2" ?
The NOS plate has 6 torque springs, most new plates only have 4. I have seen a number of the 4 spring plates fail with the spring coming loose and falling out if you do lots of hard, drop the clutch, starts . Never seen it happen with the older style 6 spring plates. Assuming it is 8.5 inch O/D and the spline fits I would happily use it even if the width of the friction face is a little less than your old plate. Just check the dimensions of the spline hub length versus the Lotus service bulletin and machine as needed to avoid the plate binding.
Just nip down to your local motor store and ask for one....or if you want all the whistles and bells...
http://www.ebay.co.uk/itm/Clutch-Alignm ... xyiBpSLF11
or if you have access to a lathe it's a five minute job...
Well, not as easy as I thought. Any tricks to getting the input shaft out of the 'box? I've removed the
front cover and the most the shaft moves out is about 1/2", then a hard 'metallic' stop. I just can't see
why it doesn't just come out. Connected somehow internally?
From what I can see from this pic and the exploded view, the lh side of the shaft is a female to receive the
4th gear shaft which is male, both keyed.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
How and how hard are you trying to get it out?
I think you have to remove it with bearings and 1st motion shaft from the case. The manual says to pull/ push the lay shaft out first, but I've never could figure out why from looking at the box.
Interested to know how you get on as likely have to do this job at some point in the future...
I aligned my clutch issuing the gear box with bell housing removed and hooked to engine host with engine on stand.
- mbell
The layshaft has a gear on it , which interferes with a gear on the input shaft stopping it coming forward.
http://www.lotuselan.net/wiki/FE_-_Gear ... rnals_%2B2
.. and it's locktite'd into place , you don't want that coming off.
