clutch release problem
I recently had a leaky clutch slave cylinder. I replaced the slave and the master cylinder. Bled the system. Adjusted the freeplay to spec. The pedal feels great I am getting 1.5 cm travel from the slave cylinder - But my clutch will not release. WHAT gives.
How much travel am I supposed to get?
-Michael Fatsi
-Michael Fatsi
-Michael Fatsi
Richmond, Virginia
1963 S1 26/0111
Richmond, Virginia
1963 S1 26/0111
mdf - First Gear
See Brian Bucklands manual - it goes into measurements needed comprehensively - unless it is just a jammed plate.
- mike in grimston
mdf wrote:FIXED. The pressure plate was stuck. I unstuck it. Wouldn't of expected a stuck pressure plate after sitting for only a couple of days.
Weird.
no I wouldn't have expected a stuck plate after such a short break....I would suspect maybe a leak from rear crankshaft oil seal which can soften and stick the plate friction material......
fred
'Never give up!....unless it's hopeless.....'
1970 S4 dhc big valve
1973 Ginetta G15
1967 Ginetta G4 [sadly now sold]
1959 lotus elite type 14
1973 Ginetta G15
- Elanconvert
