Bleeding clutch on Zetec Elan (MT 75 box)
I am at the stage of needing to fill hydraulics systems, on my Spyder Zetec Elan. The brakes are straight forward, but not clear how I bleed clutch on this gearbox. I believe it is a Ford Scorpio MT 75 box with hydraulic clutch (obviously) - slave cylinder is on inlet side of Zetec engine.
Any help out there? - is the bleed nipple underneath the rubber gaiter on the side of gearbox?
- Stratosboy
Here's a link with a bit better description:
http://forum.wscc.co.uk/forum/index.php ... -bleeding/
and I was advised by Spyder to change the 75 W90 oli and use ATF D3 fluid which is much lighter. This made a big difference to the gear change.
Colin
Colin
1971 +2S 180/5 Spyder Zetec
- spyzee
Here is a drawing from the manual showing the bleed tube (part 2). Mine seems to be a bit fiddled up as it is loosening at the tube threads rather than opening the bleeder. I have to attend to it properly this spring. Maybe see if you can get vice grips or similar on the tube while loosening the bleeder if you are unsure how tight it is?
HTH
Stu
PS Did you find the on-line copies of the MT75 service manuals for reference?
HTH
Stu
- Attachments
- MT75 Bleed Clutch.pdf
- Clutch bleeding instructions shows hose going thru the opening to the bleed tube.
- (28.76 KiB) Downloaded 617 times
Stu
1969 Plus 2 Federal LHD
thanks for this stugilmour,
I have found the pdf files for the MT75 box, but mine seems to be the opposite configuration to how it's depicted in the diagram, the feed from the master cylinder is on the side where the bleed tube is in the diagram.
I'll sort it out...!
- Stratosboy
