Clutch Slave Cylinder repair kit number
Is anyone able to confirm the Lucas number given by Brian Buckland for the clutch slave cylinder repair kit? He shows it on the Lucas box as SP2204. My local Factor looking that up has it referring to Brake Calipers. The number for the master cylinder sp1963 is correct in the factors book.
I know they are listed on ebay and Paul Matty has them but I am hoping to pick one up tomorrow if possible.
Thanks in advance for any help.
Still on a learning curve after so many years without a Lotus.
- jmp
I posted a chart of the Girling part numbers used on the various Lotus cars of the era a while back, It came in a package of info that I received when I joined Lotus Limited back in the early 90's it has a lot of useful info and most of the Girling part numbers for the cars. Take a look
Front brake puzzle
elan-f15/front-brake-puzzle-t24267.html
Gary
Front brake puzzle
Gary
The Girling repair kit number: SP2019 is for an early Ford Cortina (clutch slave cylinder part number 64067880), this kit is for a .750 (3/4) inch bore slave cylinder. The slave looks the same externally but the bore is smaller. I believe that the bore diameter for the slave used in the Elan and Plus 2 is .8125 (13/16) inch. Both clutch slave cylinders work but I think that the effort with the smaller diameter slave cylinder from the Cortina is higher.
Gary
Gary
Gary,
Have just ordered a new clutch M/C and S/C for my S4. M/C is 5/8 (.625), S/C is 7/8 (.875).
Colin.
quote="piss-ant"]The Girling repair kit number: SP2019 is for an early Ford Cortina (clutch slave cylinder part number 64067880), this kit is for a .750 (3/4) inch bore slave cylinder. The slave looks the same externally but the bore is smaller. I believe that the bore diameter for the slave used in the Elan and Plus 2 is .8125 (13/16) inch. Both clutch slave cylinders work but I think that the effort with the smaller diameter slave cylinder from the Cortina is higher.
Gary[/quote]
Colin.
Gary[/quote]
'68 S4 DHC
- fatboyoz
My bad memory Colin, happens I guess to everyone.
Gary
Gary
