Brake and clutch master relationship
I just noticed on my Sprint that the brake master cutout for the mounting in the footbox is slightly lower than the clutch mounting. Is this relationship standard across all Series?
As I look at the pushrod holes in the pedal assembly, it's hard to tell if they align with each other.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
gjz30075 wrote:I just noticed on my Sprint that the brake master cutout for the mounting in the footbox is slightly lower than the clutch mounting. Is this relationship standard across all Series?
That's certainly the same as my S4 (RHD)
S4 DHC
S4 DHC
- oldelanman
It may be a pedal ratio issue since both pedals pivot on the same shaft.
'67 S3 SE FHC
'67 S3 SE FHC
