Braided clutch hose
Hi all,
I was going to buy a braided clutch hose from Ray at RD's but these are only for a L/H drive car, mine is a right hand drive thus the hoses that Ray has are to short, I gather Ray is willing to get a batch for R/H drive cars made but needs to know the actual length of the hose for a R/H car, given that my frame and body are still divorced could I please get one of you to measure the length required or if anyone has a new as yet not fitted hose perhaps measure that for me to pass onto Ray.
Thanks in advance.
By the Way RD's and SJ's have been giving me sensational service in recent times highly recommended (by me anyway)
Tonyw
Thanks in advance.
Tonyw
Second childhood? no just an extension of my first.
- Tonyw
I have a braided SS hose on my RHD car, but just fitted a high torque starter and now find the hose is too short to fit around it.
Anyone else ever have this problem?
Jim
Temporarily Elan-less
summerinmaine - Third Gear
Jim
I have a similar arrangement to you - braided clutch hose, RHD and high torque starter. My clutch hose runs over the top of the starter between engine and starter, I suspect your hose runs UNDER your starter, try re-routing it. There is a little slack, I did wonder when I fitted it if it was long enough because of the high torque starter but it seems OK. The engine has not run yet and I may need to slightly revise the run.
72 Sprint DHC
72 Sprint DHC
lotusfan - Third Gear
My Goodridge SS hose measures around 40" overall including the right angle fitting at either end and if anything it is slightly too long. I have it routed in front of the engine mount and under the starter and there is plenty of clearance everywhere.
S4 DHC
S4 DHC
- oldelanman
lotusfan wrote:Jim
Thanks Mike! I'll give that route a try!
Jim
prloz wrote:Hi Jim,
Clutch hose on your car should run over the clutch bell-housing, then down to clutch slave. Nowhere near the starter !
Peter.
Really? I've never owned an Elan that had the hose routed that way, but it certainly sounds good. More protection from road debris as well.
I'm going to run some measurements first.
Jim
summerinmaine wrote:prloz wrote:Hi Jim,
Peter.
Don't forget that the early routing over the bellhousing was with a cast iron exhaust manifold. With a fabricated steel manifold the pipe runs too close and the workshop manual recommended rerouting the pipe through a hole drilled in the chassis top flange. On later cars the line was rerouted under the bellhousing.
S4 DHC
S4 DHC
- oldelanman
oldelanman wrote:summerinmaine wrote:prloz wrote:Hi Jim,
Peter.
Yeah, mine is a 4-2-1 header, so I'll watch for that.
Worse come to worst, I'll see if some heat shielding will help. OTOH how much could a longer SS braided hose cost?
Jim
Hi Jim,
You could do what Ford did on the Escort twin-cams. Run a pipe from the clutch slave, over the top of the bell-housing, secure the pipe with a couple of "p" clips using the top 2 bell-housing bolts, then complete the run to the clutch master with a short length of flexible hose. No problem with heat from the exhaust then.
Peter.
Peter.
- prloz
I was out playing with the car and trying to take a few measurements, and it appears that my clutch hose is ~33" from bend to bend.
Does anyone know what the measurement would be for an over-the-bell-housing route to the slave? My best measurement suggested that the hose would be about 1" too short.
Jim
