Clutch pedal on the floor
PostPost by: stuartgb100 » Fri Aug 20, 2010 4:06 pm
Took the Sprint down to London yesterday, with no apparent problems.
Returned to the car after an hour or so, and no Clutch !
Pedal straight to the floor.
No sign of any leak, and fortunately I was able to pump up the clutch
prior to each gearchange.
Back home I checked, and the master cylinder is full.
Where to start, please?
Stuart.
stuartgb100
PostPost by: AussieJohn » Fri Aug 20, 2010 4:17 pm
Sounds like a master cylinder rebuild required.
AussieJohn
PostPost by: Gray » Fri Aug 20, 2010 6:05 pm
Check cluch cylinder pipe not too close to exhaust manifold and boiling fluid.
Regards Gray
Gray
PostPost by: alexblack13 » Fri Aug 20, 2010 8:31 pm
I'm with John, although both those are possibilities. I think you will find a master cyl rebuild kit / overhaul will fix the issue anyway.
As Gray says also..Make sure the piping is not too close to the exhaust. And use a silicone fluid. ;-))
Its an easy fix Stuart..
Alex...
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: alexblack13 » Fri Aug 20, 2010 8:37 pm
Stuart..meant to say ...When buying (IF?) a service kit, keep away from the Ebay sh1t. Buy from a reputable supplier as there is a fair load of tosh out there. I bought a kit from Ebay. The post/advert showed a Girling box and was listed as such. It was from either India or China. Complete rubbish and went straight in the bin. :evil:
Careful mate.... :wink:
AB... 8)
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: twincamman » Sat Aug 21, 2010 1:44 am
my slave cylinder leaks too ---I just carry some brake fluid and top it up when I'm about to lose clutch--- it self bleeds --too much more to worry about - :wink: -ed
twincamman
PostPost by: stuartgb100 » Sat Aug 21, 2010 9:24 pm
Thanks for the replies.
A change of fluid made no improvement, so I removed the MC.
The piston in the cylinder moves nice and freely, but something
is stopping it from coming out (and yes, the circlip, dished
washer and push rod have been removed).
Will look at it again in the morning.
Stuart.
stuartgb100
PostPost by: Dr Brian » Sun Aug 22, 2010 7:51 am
Clutch cylinder rebuilds ae available from
www.pastparts.co.uk
I am a satisfied customer but usual disclaimers
Dr Brian
First Gear
First Gear
PostPost by: alaric » Sun Aug 22, 2010 11:45 am
Hi. A tiny bit of dirt on the O ring that stops the fluid going back into the reservoir when you press the pedal stopped my clutch master cylinder from working - pedal went straight to the floor. I fixed it by removing the master cylinder, stripping it, cleaning it and putting it back together. It's been fine since. My seals were'nt worn - the dirt got in there while the car wasn't in use.
Sean.
alaric
PostPost by: alexblack13 » Sun Aug 22, 2010 1:56 pm
Fair comment, But..Depending on how old etc,Its not a bad idea to fit a new set of seals when you have it apart.. I certainly would. Dont use the Indian 'Girling' ones though!!
They are sh1t and sometimes just do not work well at all.. :evil:
Going to ask me how I know? Yep.. your right!! It lasted all of a week before I took the master cyl off again and fitted a proper kit. Sorted... :roll:
Have fun girls n boys..
Alex. 8)
Alex Black.
Now Sprintless!!
alexblack13
PostPost by: stuartgb100 » Sun Aug 22, 2010 2:42 pm
Ok,
I give up - how do you get the piston etc out ?
Stuart.
stuartgb100
PostPost by: types26/36 » Sun Aug 22, 2010 3:29 pm
Stuart, have a read over this thread.....should help even though it is for the brake M/Cyl:
elan-f14/master-brake-cylinder-overhaul-t19303.html
types26/36
PostPost by: stuartgb100 » Sun Aug 22, 2010 9:03 pm
Brian,
Thanks for that.
For once I was being too gentle !
Just "tapped" a little harder.
Stuart.
stuartgb100
PostPost by: stuartgb100 » Tue Aug 24, 2010 6:46 pm
Well, master cyl is rebuilt and refixed (saw no obvious problems)
and symptoms are as before.
So I'll tackle the slave next.
Guess there's nowhere else to go.
Stuart.
stuartgb100
PostPost by: ElliottN » Wed Aug 25, 2010 2:34 pm
You're going to love rebuilding the slave cylinder (maybe you've done it before!) and you might consider a full replacement - not a lot more expensive than a rebuild kit.
Another option you might consider is to install a remote slave cylinder bleed nipple. Instead of installing the nipple on the slave, you can install a banjo union and run a s/s braided hydraulic line up to an accessible location in the engine bay and install the bleed nipple at the end of the line. Makes bleeding the slave cylinder almost civilised.
Elliott - 70 S4 dhc
ElliottN
Next
