Clutch release bearing
Before I put the engine and gearbox back together, can somebody please clarify whether I should put any form of lubrication - white grease for example - on the front face of the release bearing?
Stupid question I know but not as stupid as having to take the whole thing apart again......
Martin B
Martin B
- martinbrowning
No Grease of any kind required.
Grease should be kept well away from the Clutch.
Will you be fitting a new Bearing or Clutch?
(Sorry if that question sounds daft)
It's worth doing, considering the work needed in taking the Engine out.
Beware of the Illuminati
Thanks for the replies - no grease then other than a smidge on the pivot.
John - fitting both new release bearing and clutch set. I agree with you that whenever the engine/gearbox are split it's good sense and practice to replace the whole thing.
Martin B
Martin B
- martinbrowning
